      Sep 2011
      Altamonte Springs, FL
      Rotted Body Mount
      Need some help. (Second Gen Camaro) I just checked the area where the body meets the fron frame on the drivers side behind the front wheel and discovered that the metal where the bushing should attach is no longer thier. The bottom where the nut and the buching would bolt too is gone. Does anyone know how dificult of a repair this would be?? Cost involved? I think my description is good but I can take a picture of the area if needed? Thanks for any info you guys could provide.
      May 2011
      central Pa, USA
      I would certainly recommend posting up a picture, they're worth a thousand words you know... As far as how to fix it, depending how much is gone you may be able to just lap weld a plate in place and call it a day. If that wont work Im sure you can get a patch panel to weld in.
      Tom
      trailers are for boats and broke stuff.
      Jan 2011
      Boston, MA
      Hey, just saw this thread. I had the same problem on my first gen, the ones behind the front wheel are the most common to rot. They make patch plates for this. They are around $50 for a set of 6 (http://www.rickscamaros.com/camaro-s...1967-1981.html). 4 of mine were rotten, so I had the old ones cut out and the new one's welded in. My mechanic was able to drop the subframe a couple of inches and do it while it was still on the car. It cost me $400 for all 4.
      If your's aren't too bad here's a cheaper option: http://www.rickscamaros.com/camaro-s...1967-1981.html
      This is what mine looked like:
      Aug 2005
      Hamilton, NJ
      I had to replace one on my frame.
      http://www.njfboa.org/forums/showthread.php?t=31106
      Scott from NJ.
      Vent Windows Forever! ...
      Sep 2011
      Thanks for this info guys. Turns out the plate rotted and the upper piece poped the spot welds. I am just now getting back into this build and will post some pics. It is not pretty but i think with your info (Thanks 67 Rally) i should be able to get it right.
      Sep 2011
      Pic of seperated mount
      Name:  Body Mount.jpg
      Here is a photo of how the mount came out after i removed the bolt.
    Tags for this Thread
