Results 21 to 40 of 41
Suspension balance/correcting oversteer
I am needing some advice on how to correct some oversteer in my chassis.
The car is an 80 TA with ws6 springs front and rear, tubular upper arms with steel bushings, rubber lower a arm bushings, rubber springs in the leaf springs, edelbrock shocks, and 17 x 9 tires front and rear. On the rear, I ran the adaptors 1/2 inch wider to add some roll stiffness to the rear and in this condition it had a little understeer.
I added front structure braces from pro touring f body.com and solid body mounts and the car was balanced the way I wanted it.
I added a shear plate across the structure braces to add some torsional stiffness and to take some load off of the firewall. This worked as planned and now the front is tight and almost rattle free. The problem is now the car oversteers significantly when pushed on tighter corners. It oversteers so much that I am a little un comfortable with it.
To correct this I think I need to soften the front or stiffen the rear. I wanted some feedback before I made any changes so I get it headed in the right direction the first time.
If I need to soften the front, that would be fine with me as ride is porbably more important than max g's. There is a 6 cylinder bird in the junkyard that I can get a smaller bar and softer springs from cheap or new springs are not that pricey.
If I need to soften the front, which will have a greater effect on a softer ride, a smaller bar or softer springs?
