    Results 1 to 1 of 1
      Feb 2010
      Central NJ
      T56 swap trans mount tab relocation
      Hey Guys!... I'm in the middle of swapping my Super t-10 for a t56. I've been researching the web for what I thought would be a consistant answer to a some what common question: How much to drop the mounting tab when swaping out a 4-speed or th350 to a t56... haha, maybe its not that common, but logic would lead me to believe that positioning the output shaft in the same location as the previous (4-speed) output shaft would be ideal... please let me know if this makes sense, I'd like to cut once/weld once if I could..
      In order to position the t-56's output shaft in the same location as the T10's i measured from the trans mounting flange to the center of the output shaft on both transmissions... the t-10 was 2+3/4" (+/- 1/16) and the t56 was 3+3/8" (+/- 1/16)... so I'm looking at a difference of about 5/8". This leads me to believe the tab needs to be located 5/8" lower on the t56 to achieve the same location/driveline angle as the t10.
      Based on what I found on the internet, Most guys are dropping the tab anywhere from 1" to 1+5/8"... and keeping the trans mount from the early trans... Am I doing something wrong??
      the car was was original equipped with a th350 and that crossmember was used when I swapped in my t10, that being said, I'm not sure if the th350's output shaft centerline/trans mount flange are the same as the t-10's
      For optimum clearance, dropping the tap 1+1/4 - 1+1/2" would "visualy" leave more room for the u-joints from the floor, could be shimmed up to acheive a better angle (if needed) and since my Rear UCA's are adjustable could help with any changes in drive line angle... Is this correct to assume???
      thanks in advance and sorry if I just plain confused you..lol
      -Sean
