      Oct 2007
      Atlanta
      glass polishing?
      Anyone had good luck polishing out minor scratches in glass? I have looked at the kits out there that mainly use a cerium oxide paste to polish out imperfections, but don't know how well they work. Is it worth doing?
      Texan Back in Texas!
      They used a kit on Trucks, or Musclecar on an old, very worn, windshield and it seemed to work very well. I think it takes allot of time to do it right, but definitely cheaper that new glass.
      1965 Falcon Hardtop
      Orangevale, Ca
      You can achieve good results on MINOR scratches with a felt wheel that attaches to a drill and a cerium oxide paste. But usually anything that is deep enough to catch your fingernail when running across will not come out without distorting the glass. Many years in the glass business...this being a common problem.
      Dec 2010
      Fredericksburg, VA.
      Will one of these polishing kits remove the wiper scratches?
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Knoxville TN
      I just recently scratched my quarter glass during a mini tub prep
      Mar 2012
      with a glass repair kit you are sanding the scratch out so it will leave a divot in the glass
      Aug 2008
      jacksonville,fl
      It is slow & messy,as said only for scratches you can't feel with your fingernail. 3-m has discs that will actually sand glass That process is REALLY slow to get all the scratches you just made back out, In other words mainly use for non replaceable glass.
      When talking about removing scratches or polishing, the whole process is basically removing larger scratches with smaller scratches till you can't see any. This applies for any material.
      I have used metal polish at work on small areas, one with heavier grit will of course cut faster.I have also used my same silicone carbide sandpapers used for paint colorsanding to remove heavier scratches. You can try a small area to see how much patience you wll need. Main rule is NOT to stay in one spot too long, You can also get glass hot enough to crack.
