Thread: adjustable master cyl t56
07-04-2005 #1
New to Pro-Touring
- Jan 2005
- houston,texas
- 43
i need a adjustable master cyl for my 72 camaro. the new gm piece i had broke right where the pedal linkage and rod are crimped together. anybody know where to get one.
1972 camaro SS |13.5.1 comp solid roller 406| 698 rwhp 713 rwtq & t56 6 speed | G machine |10 secs & 200 mph top end
07-14-2005 #2I had the same thing happen butI just threaded the end of the rod and made it adjustable. I think mcloed sells them
07-14-2005 #3
Banned
- Nov 2003
- Maine
- 1,076
master
yeah just thread the gm rod and use a femal erod end or a coupling and a male rod end to couple it to the clutch pedal, then make sure you do not have over 1 inch of travel as you will blow out master
jake
07-14-2005 #4
New to Pro-Touring
- Jan 2005
- houston,texas
- 43
Thanks for the help . im going to do the rod end trick. but as luck has it. i was in the car working on the gauges and had to move the shifter. well now the trans is stuck in gear.
