      Dec 2009
      Austin, TX
      What the Electrical
      Information about the 1969 Firebird
      Autometer electrical guages
      Vintage Air A/C with 3 Knob servo control
      Interstate battery holding a 12+ Volt Charge entire time
      New Starter and showing 12+ Volts at the battery cable terminal
      Ford Mark VIII Electric Fan works off Temp switch
      Electric Choke on the Holley Carb
      LED Taillights with proper flasher relays
      Single wire Altenator
      New Horn Relay
      MSD 6A and Distributor
      No Voltage regulator
      I have the electric fan running off a Painless Wiring Relay fuse circuit that comes off the battery for + Voltage.
      Problem:
      No headlights, No tail lights, No turn signal lights, No Horn
      No Click when attempting to start the car with the key
      When attempting to start the car the dash Mileage LEDs light and fade out in less then a second.
      Interior light (under dash) (convertible) comes on and fades out once attempting to start car. Will not come back on until has sat untouched for a while.
      All fuses under dash are ok
      All fuses in Engine bay are ok
      I have 12+ Volts on the fuses under the dash.
      Everything on the car was running perfect for several months and all of a sudden this happened over night. Wife drove the car for 3 days (Wed-Fri) and then I drove it on Saturday Morning. Then Sunday morning nothing this issue happened.
      Anyone have any ideas of what to start debugging?
      Ray
      May 2007
      Ugh. Stuff like this is why I'm requiring my car. I hate debugging. I assume you are running the original harness? Start with the grounds.
      Dec 2009
      Austin, TX
      Well today was interesting; the bird has sat untouched for about 2-3 weeks. I went out to pull the dash to get the Headlight switch out and the headlights and dash were working normally.
      I grab the keys and attempt to start the car and I get a click and then the power goes out again (back to the original problem).
      May 2007
      Quote Originally Posted by AM.MSCL View Post
      And all this time you are getting 12v at the fuses? I'm no electrical guru, but it sounds to me like you've got a groumd issue... A big one.
      Aug 2008
      ocala fl
      Country Flag: Wales
      First thing id do is check the battery terminals make sure they’re clean and tight. Then I would load test the battery make sure it has good voltage when someone is trying to start the vehicle. Your battery may have a internal short that wont show up unless under load
      ''Courage is being scared to death
      - But saddling up anyway''.......John Wayne...
      Anthony
