      '67 Mustang with GM steering box?
      Is this something to even consider? Tri-5 boxes look very similar in mounting, but have never had one of each to compare. I want power steering, but not the stock set up. Can a front steer box work on a rear steer car? I have seen alot of R&P set ups but it is a driver and my pockets are not that deep.
      brian have you checked out www.randallsrack.com ? randy is a great guy and his rack isn't all that expensive. i'm sure it's a bit more than the tri-5 box but the tri-5 box is a custom piece as well. i plan on going with randy's rack on my car as well. his looks to be about the best engineered short of a tcp or rrs rack and about half the cost of those
      Do you have a 69 or 70 stang? If so then check out www.69STANG.com
      Jun 2003
      Chicagoland
      Quote Originally Posted by brianj5600
      I know that have read something along these lines on the geek-net. Something like using a corvette (year ?) steering box in a Ford application. If I find the link I will post it.
      W.
      William Rouleau
      Project PonySnake - '67 Mustang Fastback
      May 2004
      Dallas, TX
      What is the advantage of a chebbie box over the Ford unit? I put a blu-printed GW box in my 68 coupe....I have yet to drive the car so I can not comment on its performance.
      Quote Originally Posted by kmcanally
      Power assist is integrated. Much simpler than the nightmare Ford came up with.
      Fontana, CA
      Agreed. Nightmare is the nice way of putting it. I can not tell you how much s#$t I had to do to the power steering on my 66 coupe (my first car, R.I.P.).
      Nick R.
