      Oct 2005
      New Washington, IN
      Cam recomendation comparison
      If anyone saw my Air Force 69 build update, I discovered my new 260hp crate engine block is cracked. So I am going to swap all the parts into another block, and thought, heck, I might as well get a better cam then stock.
      So I filled out the questionare for 2 companies.
      Company A recommended this
      Intake Duration at 050 inch Lift 213
      Exhaust Duration at 050 inch Lift 219
      Advertised Intake Duration 256
      Advertised Exhaust Duration
      Intake Valve Lift with Factory Rocker Arm Ratio 0.454 in.
      Exhaust Valve Lift with Factory Rocker Arm Ratio0.468 in.
      Lobe Separation (degrees)112
      Company B recommended,
      Intake Duration at 050 inch Lift 212
      Exhaust Duration at 050 inch Lift 218
      Advertised Exhaust Duration268
      Intake Valve Lift with Factory Rocker Arm Ratio 0.447 in.
      Exhaust Valve Lift with Factory Rocker Arm Ratio0.454 in.
      Lobe Separation (degrees)110
      I was glad to see how similer the 2 recommendations were. Only real difference I see is the LSA. And of course a hair more lift on one.
      Which do you guys think would be better?
      Stock 350, 8.5:1 Performer intake factory Q jet, rams hon manifolds dual 2.25" exhaust. Muncie 4 speed, 3.73 rear gear, 28" tire, 3400 vehicle weight. Driver, truck.
      1971 Camaro 427 in waiting
      1988 C1500 Daily Driver
      Oct 2005
      New Washington, IN
      Cam b made 23hp and 20ft lbs more than cam a on desktop dyno. What a shock!
      Oct 2011
      Philipsburg, Pa
      Hey JB. I'm starting the search for an autocross cam. I'm interested to see what goes on in this thread as I'm also a "cam spec junkie".
      I've used the CS-1028R in a few different engines and it just seems to work for everything. http://www.northernautoparts.com/Pro...?ProductId=688. It's similar to your specs but it's single pattern which I like and is inexpensive.
      ramey
      Technical Support
      UMI Performance, Inc.
      [email protected]
      814.343.6315
      Join us on Facebook!
