    Results 1 to 10 of 10
      Oct 2005
      67-70 Mustang Ride Tech Parts
      Ride tech formerly known as air ride Technologies Suspension Parts-
      Tubular Upper and Lower Control Arms (Strong Arms)
      Ride Tech Muscle Bar with Posi Links
      Ride Tech Muscle Bar Triangulated 4 Link setup with Air Bags and optional internal ride height sensors (this makes for a much more accurate ride height setting as it uses sensor as well as air pressure - this is an $400 add on to each air bag)
      MSRP on the upper/lower strong arms is $1100 usd
      MSRP on the muscle bar front sway bar is $400
      These control arms/sway bar can be used with either Air Bags or Coilovers (ridetech now makes adjustable coilvers to go with these kits)
      Looking for $1200 on the control arms and the sway bar.
      MSRP on the Air Bar 4 Link is $1300 - Looking for $1000
      MSRP on the Rear Air Bags is 900 plus the 800 to have them updgraded with internal sensors - Looking to get $1200
      Ride Tech 5 Gallon Air Pod with twin compressors, upgraded ECU to ridepro and optional Internal Sensors - brand new - used only to mock up the above suspension parts
      With the options and add on's this sells for $2750
      Looking to get $1900
      The Ride Tech parts were only used for mockup, and have no actual miles on them. I decided to change engines in my car, and go a completely different route with suspension; as a result, I have no use for the ride tech stuff.
      Also have 67-70 Mustang Baer Brake Hub assemblies with Baer Brake bracketry for 13 or 14" brakes, and Baer Brake rotor hats
      These aren't normally sold in pieces like this (the 13 or 14" 6 piston baer kit will run about $2400)
      All you would need are rotors and calipers
      Looking to get $500 for the brackets, spindles, and hubs
      Also have a 67-70 Mustang Rack and Pinion Complete steering setup - this was used for approx 800 miles (a summer and a half before I took my car off the road to change it) The new front clip I have includes a rack and so I have no use for this anymore
      This comes with the power steering pump, and bracketry for a windsor based small block
      Looking to get $800
      As you can see I've priced things individually, but ideally a package deal would work best for me. All these parts together makes for a pretty sweet setup in a 67-70 Mustang - it bolts right in and can be removed or reversed if there was ever the desire to go back to stock.
      Tom
      Jan 2007
      Port Orchard, WA
      pm sent on airpod
      Oct 2005
      Also have 2 double adjustable shockwaves with internal sensors for sale... Looking for 1150
      Jan 2010
      Long island NY
      Quote Originally Posted by 67greengt View Post
      Pm sent on fronts
      70 Mustang fastback 428 sb
      Oct 2005
      Shockwaves re listed in separate ad
      Mar 2010
      Norway
      Country Flag: Norway
      email sent!
      65 mustang HT no name
      67 mustang HT red rocket
      Oct 2005
      Air Pod is still for sale.
      Front Upper/Lower Control Arms, Muscle Bar and Rear 4 Link have sold****
      Sep 2007
      What"s the best price you would do on the front spindles and baer parts.
      Mike
      [email protected]
      what brand is the rack and pump
      Oct 2005
      The Rack and Pinion is a Randalls Rack and Pinion kit with the power steering pump and the lines - the pump is the same pump that DSE sells (I believe its an OE Corvette replacement pump)
      Hope that helps
      Tom
