      Aug 2011
      Sevierville, TN
      catch can advice
      OK, I recently ran at a GoodGuys autox event. Upon tech inspection, I was told told I have to have a catch can for my radiator overflow. The quick fix to run the autox was to quickly suck down a Mtn Dew, and strap it on with a bungee cord. Well, although that worked as a temporary solution, I really don't like that as a permanent solution.
      Now, before I restored my truck, I used to have one of the aluminum tube style cans(similar to url=http://www.billetspecialties.com/itemdetail.asp?cid=7&scid=86&pid=209&sb=overflow&p g=1]this[/url]. The problem was it was mounted on the opposite side of the drain. I really don't want to mount it all the way over there again. It's designed to be mounted vertically, but there's no room where it needs to be because the battery and tray is in the way. I'm considering mounting it horizontally under the battery tray.
      Is this even a viable option? Would it still work horizontally?
      Matt Kenner
      68 C10 stepside
      If you can leave two black stripes from the exit of one corner to the braking zone of the next, you have enough horsepower. - Mark Donohue
      Beach Park IL
      Mine is. I just made a can out of three inch tubing with an in and out tube welded in. it won't spit until it is all the way full. the off the shelf ones that mount vertical will NOT work mounted horizontally.
      Donny
      As long as the radiator side is on the bottom -- so that fluid can be drawn back in when the radiator de-pressurizes -- orientation doesn't matter.
      ​John Parsons
      Jun 2010
      Georgia
      if you don't find a solution, we can make them for vertical mount, horizontal mount, round, square and anywhere in between.
