11-07-2011 #1
- Mar 2008
- 8
Getting a 69 camaro to handle...on a budget
This is not my first experience with 1st gen camaros, but I don't have near the budget I did 8 years ago. I have recently purchased another 69 and have about $6000 for suspension/brake parts. I want it to handle as well as my 02 ss that has an upgraded sway bars, subframe connectors and pan hard setup. If possible I'd also like to use the existing 275/40/17 on the front.
I'd like to lower it slightly, and since last working on a 67 six years ago things seemed to have changed. That car had a drop spindle on it, running those size of tires up front with a different wheel and a 13" wilwood setup with a hydra boost. I would like to run something similar and get it right the first time as I believe I had 3 different tries on that.
This 69 has manual brakes and steering and I'd like to install a 600 series power steering box
on it. Down the road I may also want to run an LS3 with a 6 speed trans and do NOT want to have to pull off parts to do it. Modifying the existing front subframe is okay, though I'd sure like to get some weight off it.
It will be a dd that will see 10-12 road course sessions a year and maybe 4-5 trips to the qtr. I know there are lots of ideas out there, but with my goals and budget perhaps they can be narrowed down? Ideas that will fit in these parameters?
