    Results 1 to 20 of 24
      Oct 2007
      Georgetown/Austin, TX
      New ProForged Upper Control Arms
      I saw these at SEMA last week and thought I would share. I had a very lengthly conversation with Zack Kanter, President of ProForged, about the arm's design. It uses a 0.9" taller screw-in ball joint, has adjustable caster slugs, and provides extra tire clearance. Pretty cool pieces. He did say that they won't be ready to ship until the beginning of 2012.
      Nov 2010
      Ventura County CA
      The option list for tubular arms continues to grow.
      Some questions:
      - How much reward offset is built in for increasing caster and what range of adjustment do the slugs have?
      - Will there be a bumpstop added?
      - MIG welded? looks like it
      - Tubing size(s)?
      - Mild steel DOM, chromoly or?
      - Country of origin?
      Oct 2010
      Rockaway. NJ
      Subscribed.....
      Troy
      67GTO
      St George Utah
      Quote Originally Posted by TheBandit View Post
      Some questions:
      - Tubing size(s)?
      eagerly waiting to know.
      Blake Foster
      www.speedtechperformance.com
      435-628-4300
      St. George Utah.
      it's always sunny here.
      Oct 2007
      Some questions:
      - Tubing size(s)?
      He did say that there would be different slugs offered so you could fine tune the caster, with the max gain being 5 degrees, but I'm not sure how much is built into the arms and how much comes from the slugs.
      I sent Mr. Kanter a link to this thread so I'm sure he will be in here shortly with more specifics than I can offer.
      Lawrenceburg, TN
      Jan 2009
      Cliff - thanks for posting this up and sending us the link!
      These are a flat arm designed for maximum clearance. To my knowledge, they are the only tubular arm on the market that uses a 0.90" taller ball joint. This tall ball joint achieves an aggressive but streetable negative camber curve. We use a screw-in style ball joint for a clean design and maximum travel in all directions. Low friction Delrin® bushings are used for smooth and predictable handling.
      Some questions:
      - Tubing size(s)?
      Thanks for the interest! These arms are the first prototypes and we are still in the process of nailing down a final design. The preliminary answers are below:
      - We are shooting for 3-5* positive caster at max adjustment. The final figure depends on the amount of frame clearance we have to work with. When we have a final figure, we'll definitely post it up.
      - We will be including 3 slugs - "0" offset (seen in the photo), a mild offset, and an aggressive offset. The aggressive offset slugs currently have the ability to move the arm 0.375" from the "0" offset position. This would end up being somewhere between 3-5 degrees.
      - It is MIG welded in the USA.
      - The tubing is 1" OD, .219 wall thickness, 1018 mild steel DOM.
      Birmingham, AL
      Glad for another choice. Hopefully there will be options for second gen Camaros.
      Stephen
      Aug 2009
      Quote Originally Posted by srh3trinity View Post
      Good question:
      What applications are these going to be available for? Any plans on a lower control arm as well?
      Lawrenceburg, TN
      OK send me a set, if you must I will test the crap outta them
      St George Utah
      Most Excellent design, if i must say. Looks striklingly simular to the set i sold you 6 months ago
      Blake Foster
      435-628-4300
      St. George Utah.
      Aug 2006
      San Francisco, CA
      It looks like a hybrid of several manufacturers, some cool features of each incorporated into this arm, along with some unique ones.
      Steven
      1968 Camaro: Project "TRACKDAY"
      Latest Track Weekend Video
      Build in Progress
      Jan 2009
      Quote Originally Posted by killer69 View Post
      I did buy a set of these from you back in April 2010, almost 2 years ago. Anyways, the profile of your arm is great for wheel clearance and when we started designing our arms we certainly thought back on the Speedtech arm's profile. The profile of the arm aside, they are very different - we use a screw-in, 0.90" taller upper ball joint vs. your stock length, 4-bolt upper ball joint, and we have a caster slug adjustable cross shaft vs. your fixed cross shaft. Our bushing design is a unique, low friction Delrin® configuration that allows the cross shaft to rotate so freely that you can move it by hand. Our arms and your arms serve two very different purposes...it seem that yours was designed mainly for wheel clearance and use with a tall spindle, whereas ours is built for geometry correction with stock spindles (although we will also have a standard-length screw-in ball joint version for people using tall spindles).
      In terms of the high clearance shape...the location of the frame mounts and the other obstacles really dictates the shape of the arm - this is why so many arms come out looking strikingly similar:
      May 2002
      Northern California
      oh, here we go again.... " a perfection of a component may often resemble another simply because it maybe the only way to build it "
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Jul 2009
      Sackville, NB, Canada
      Are there plans for a G-body version?
      Tyson
      '95 Firebird Formula: suspension + 315's
      '66 Mustang Coupe, 289
      Jan 2009
      We are doing the A-Body arms next, then 2nd Gen F-Body. G-Body arm are a possibility in late 2012.
      Oct 2010
      Rockaway. NJ
      Quote Originally Posted by Proforged View Post
      Troy
      67GTO
      Nov 2010
      Ventura County CA
      Thank you for responding to all my questions. Do you have a target list price?
      Jan 2009
      We are shooting for $649-699 per pair.
      Jul 2011
      Nashville, TN
      what is the distance between the bolt holes on the cross shaft?
      What is the effective length from cross shaft to balljoint?
      What taper is the balljoint? chrysler? ford? gm?
      Reason I ask, I know what I'd need, but no one makes a ford galaxie application UCA. Other MFGs started r and d, but refuse to bring them to market. I'm not paying thousands of dollars for a one off set.
      -Dave
      Project George - '66 Ford Galaxie 500 fastback
      Working on interior, body and paint now.
      Forged 306/C4. Collecting turbo parts for TT setup.
      I have tons of 65/66 galaxie parts collected. If you need something, just ask! my wife will thank you.
