    Thread: Tach signal
      Sep 2011
      Dana Point, California 92629
      Tach signal
      68' Camaro - I am using a stock tach with my LSA swap. I purchased a Dakotasignal converter... but I don't detect any juice coming from the ECU? Is there a command or something I should havehad programmed to run this set-up?
      I read somewhere that you have to tap a switched 12v source and tie that to the tach signal wire with a "pull-up" resistor. Try this link:
      http://67-72chevytrucks.com/vboard/s...d.php?t=445975
      The injected voltage along with the DD signal convertor should fix your tach.
      GeoffP
      68 Camaro - LS1/T-56
      Sep 2011
      Thanks!
