11-03-2011 #1
Trick flow LS1 Beehive Valve Springs
I have a like new set of trick flow .600 lift Pacaloy beehive valve springs for sale. They have 200 miles on them and were replaced with a set of double valve springs to match the new camshaft that was installed. The ls1 they were on was a street engine that was never raced. They have been checked on a rimac spring tester and have the correct installed and open pressures. They fit all ls series engines except ls7, ls9 and LSA. They also fit small block Chevy and late model hemi 5.7. They will fit all applications with 1.800 installed height. I paid 140.00 for them new and I am asking 105.00 shipped
Installed height 1.800 inches
Installed pressure 130 lbs
Open height 1.200 inches
Open pressure 318 pounds
Coil bind 1.140 inches
Outer diameter 1.290 inches
Rate 313 lbs per inch
