      Dec 2010
      Lynchburg Va
      Questions about axle options
      O.K. to start I have a Dana 60 rearend sitting around and want to replace the mopar 7.25" rearend in my 65 sport fury. It is a FF from a 1978 F250 (RIP).
      What I want to accomplish is
      1. I am going to narrow it. How much I am unsure of yet as I haven't taken any measurements.
      2. I would like to keep it a FF but obviously am not going to be running 8 lugs on the car. Does anyone know of a spindle kit that can be used. I have seen some 9 inch FF's built and was wondering if those parts would be workable on this. Also who makes them?
      I expect I'll get a line up bar and machine some pucks at work when the time comes. Just trying to figure out if I can actually accomplish what I want before getting into it.
      And just to be clear I will be doing the work myself.
      Thanks for any input.
      Greg.
      Dec 2010
      Lynchburg Va
      Short followup. I see that Currie makes a kit to do exactly what I am proposing. Not cheap but includes brakes and Wilwood calipers. I was thinking of getting a D44 front spindle and figuring out a way to get the axle engaged but I see they use a warn locking hub (yes on the rear) or sell a drive flange kit to engage the axle. Might try to see what I can come up with there.
      Also saw that Moser makes a kit as well. Warn used to make one but they do not any more. Ideas are flowing. This could be bad.
      Dec 2010
      Fredericksburg, VA.
      Check Moser's Circle Track rear ends and floater kits.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Loganville, GA
      I would look at the 9" circle track rear ends as well. That Dana is a heavy sucker with very thick tubes. The 9" floater would do everything you want without the weight penalty.
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
      Jan 2009
      San Antonio, Texas
      Quote Originally Posted by Randy67 View Post
      X2. My custom built full floater 9" just arrived - got it from Speedway Engineering (not Speedway Motors - they don't do custom stuff) - real nice piece.
      Scott
      Check out my YouTube channel for vintage car and truck rescues and rebuilds! THE BULLETPROOF GARAGE!!! - YouTube
      Dec 2010
      Lynchburg Va
      Yeah I realize I'd be better off using a 9". Thanks for the input on what's out there. I'll update this again when I figure out which route I want to go. May be a while before I move on it.
      Greg
      Dec 2010
      Lynchburg Va
      Still researching it looks like I might be able to use a Chevy small bearing spindle from a front D44. Now just need to figure out the hubs/brakes. (edit) Just had time to really dig through Mosers website. You can get any part needed and pricing is realistic too. I am a retard for not just looking through all that in the first place.
      So out of curiosity what is the weight difference, roughly, between a 60 and a 9".
      Greg
      Loganville, GA
      A search lists a full-floater Dana 60 from a truck near 500 lbs.
      1975 MGB Roadster
      2003 GSX750F Katana
