      Oct 2005
      New Washington, IN
      Aluminum hard line
      Are there any drawbacks to using aluminum hardline for plumbing fuel system. Using soft line at needed connections of course.
      1971 Camaro 427 in waiting
      1988 C1500 Daily Driver
      Aug 2008
      ocala fl
      Country Flag: Wales
      All factory cars at one time used steel lines. I personally like stainless steel line. These days they use a plastic fuel line which is ethanol resistant and wont rust. I wouldn’t like to use aluminum lines of the length required to run from the fuel tank to the motor the aluminum line seems to be a little soft. There may be a issue with vibration and fracturing although vans with rear a/c use aluminum lines with out any problems. Good luck with that one.
      ''Courage is being scared to death
      - But saddling up anyway''.......John Wayne...
      Anthony
      Mar 2004
      Mid-Michigan
      I am going to go with 1/2" steel hydraulic lines. Reason being as stated above, PLUS I don't like the idea of ethanol laced gas sitting in an aluminum line for a long period of time.
      Mark
      Mark:
      This my Bad Ast thread...
      This is my Fotki album...
      http://astroracer.fotki.com/
      Loganville, GA
      If you do use aluminum line, make sure to support it with padded clips or similar. Don't let it rub against anything under the car either. It is easy to form and bend which is nice, but I would go with steel myself if possible for a bit more of a safety factor. That and the ethanol factor as well.
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
      Aug 2005
      Hamilton, NJ
      road debris cuts through aluminum like butter. OEs used to use steel w/rock guard (spring looking wrap) for a reason.
      Scott from NJ.
      Vent Windows Forever! ...
