Thread: ride tech e3 problem
10-29-2011 #1
New to Pro-Touring
- May 2006
- 37
I have a 56 that i installed a e3 airpod system on and it has worked great all summer....But i have not started the car in a month so the battery is dead...hooked up cables and the car starts but i see that the control panel for the airride is not on...Checked the fuses on the tank and the middle 15 amp fuse is blown the other 15 and two 30s are good. compressor comes on but still no display iam getting all the power and the switched 12v from the ignition but no display ... I checked the display cable both on the ecm and both ports on the display...The display/control has no function at all. I have called ridetech but the are closed for the weekend so hopefully some one here has a idea...Have they had issues with the displays? You can't really bypass the display so untill i find out whats wrong this thing is dead in the water...Any help or ideas would be great thanks Bret
