      Melbourne, FL
      Molex or Metri-Pack 150 ???
      I'm in the process of wiring up my gauges and dash lights/indicators. I was looking at using either the Molex or Delphi Metri-Pack 150 connectors. I noticed that the Molex ones seem to be a lot cheaper. Since these circuits would be pretty low amperage circuits would the Molex ones be suitable?? Or should I use the Delphi ones??
      67 Firebird Convert 455 +.060 Johnny Winters TH400 74cc KRE d-port flowed @ 310 cfm heads piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
      Honest dad that 455 on the side of the block is a serial number
      Feb 2007
      USA, TN
      Put both terminals in your crimper and you'll throw the Molex away. Also, most of the Delphi parts are American made, or at least they were a couple of years ago. Check out www.mouser.com for good prices on the Delphi connectors. I don't know which gauges you are using, but there is a 3 pin series 56 connector that fits some of the Autometer gauges.
      Melbourne, FL
      So I assume that the Molex terminals are a PITA to crimp ??? I'll check Mouser and Waytek for prices on the Delphi stuff.
      I checked out Waytek and they do have good prices. But, they don't sell the unsealed Metri-Pack 150 connectors. I guess you can use them without the seals. I'd rather not deal with the seals from under dash use.
      Woodstock, Ga
      I have not used them myself, but have noticed waytek wire sells the metri-packs. They also have a lot of other cool stuff and have pretty quick delivery.
      Here is a link to the multi pin automotive connectors including metri-packs.
      http://order.waytekwire.com/scategor...%20Connectors/
      Robert
      Caledonia, MI
      I use both on a daily basis. If given a choose I would use the Metri Pack connectors all day long. Mouser.com and powerandsignal.com are both good places to get them.
      Jason Mitchell
      1969 Camaro @ Dutchboys
