Thread: 79 TA Tire Wheel Question
10-22-2011 #1
- Oct 2011
- Canfield Ohio
- 22
This may be already on here but I can't seem to find it.
I am having some 18" wheels made for a 79 TA. All things being stock other than the rear suspension will be changed to coil overs. I am looking for a idea and starting point on how much tire I can stuff under this car, both front and back.
Car will have a 500 hp 455 in it so I need some rear tire under it. Tubs could be an option.
Help anyone? I am getting the tool to measure rims and such but just want an idea.
10-22-2011 #2a 295 is about it on a 9.5" wheel, and you'll be banging on your seat belt bulge to get those in there. Some people have been able to get a 315 tire under a firebird, but those cars sit a bit higher to avoid interference with the fender lip and the top inside of the fender. So how low do you want to go.
Greg
1976 Trans Am SacrilEdge
twin turbo 455
Ttops and 4spd
one of 110 made
https://www.pro-touring.com/showthre...ect&highlight=
https://www.pro-touring.com/showthre...ilEdge-is-free!
10-23-2011 #3
- Oct 2011
- Canfield Ohio
- 22
I was looking to have the fender lips just over top of the wheel by maybe an inch or so. I might not be able to go that low though as the headers would hit all the time.
I went and checked out your post and I like where yours are in relation to the fender lip. I also was planning to use Year one Honeycombs on mine. Not sure if yours are thier "stock" version or the custom made ones. The custom made ones was where I was going. ALTHOUGH getting the tubos widened and redone might be kinda cool, the down side they are a 15" rim. My car is going to be a updates version of the TATA. Think of a TATA Year One version, but not identical, just a baseline.Last edited by 10Aniv; 10-23-2011 at 02:17 AM. Reason: Added wording
10-31-2011 #4I used their "cast" 17" wheels as they are more true to the originals. I had the rears widened 2.5" to fit the 335s. At 4-5" lowered, the front wheels rubbed on the inner fender too much (but looked so cool). I had to raise it back up 1-2". You could run 255s at that height and probably be OK. The 275 in the back was fine lowered 4", but I did have to massage the fender lip a little to keep from cutting the tire. 4-5" drop is quite a bit if you don't have some serious suspension mods. A 3" drop is reasonable, however.
Greg
twin turbo 455
Ttops and 4spd
one of 110 made
