    Thread: LT1 fuse box
      Melbourne, FL
      LT1 fuse box
      I picked up a fuse/relay box from an 03 LT1 to use under the hood for extra relays/fuses. It has TONS of slots for fuses and relays. I know I'll never use all of them. So I was wondering. Should I completely strip out all the existing wires and only wire what I need?? Or try and trace each wire and solder connections as needed. My gut feeling says to strip it and just wire what I need.
      67 Firebird Convert 455 +.060 Johnny Winters TH400 74cc KRE d-port flowed @ 310 cfm heads piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
      Honest dad that 455 on the side of the block is a serial number
      Feb 2007
      USA, TN
      The terminals are pretty cheap. If you are ok with crimping your own, I'd strip it out and start over. You may be able to reuse any buss bars in it.
      Melbourne, FL
      I have no problem crimping and soldering my own connections. But I can see where this might be a tedious task. At least I'll have someting to keep me busy over the christmas holiday ... LOL
      Feb 2007
      USA, TN
      It definitely takes some time. There is no real need to solder a properly crimped Metripack terminal. Make sure you have a good schematic before you start.
      Melbourne, FL
      Ok Thanks. I plan on buying a good quality crimper. And a good schematic is definitely a MUST. I think I'm in my 3rd itteration of all my dash/gauge connections.
      Feb 2007
      USA, TN
      I have a Visio of my dash wiring if you are interested.
      Melbourne, FL
      Thanks. That would probably be helpful. I'll pm you my email. PMs full
      Feb 2009
      So-Cal
      just a heads up, there is no 03 LT1. They were stopped in 97.
      65 Buick Skylark: Getting a LT1 and T56
      95 Camaro: DD commuter project, LT1/T56/T-Top swap
      07 Kia Spectra: Current commuter
