    Results 1 to 18 of 18
    Thread: Retrotek
      Sep 2011
      Retrotek
      Does anyone know if Retrotek discontinued their push button shifter?
      Norway
      Country Flag: Norway
      I was wondering the same thing...
      Arne A Hjemaas
      Sep 2011
      For my future project I was thinking about doing the Shrifter with the Retrotek push button to get rid of the floor shifter. Have a custom center console built. But I haven't been able to find anything on the push button. It's not on their website or anything.
      Sep 2011
      I just received an email from Retrotek saying that they no longer manufacture or sell the Smart Shift system.
      Norway
      To bad, any other option?
      What about the TCI "Shift-By-Wire Shifter Systems" what happend to that?
      http://www.superchevy.com/multimedia...931/index.html
      Arne A Hjemaas
      Sep 2011
      I haven't checked on that one. I did receive an email from Master Shift and they are still carrying their push button shifter. So that was good news.
      Jan 2003
      Arizona
      For safety reasons, it's a very difficult product to make work in aftermarket applications. A new Jaguar has shift by wire, but every car rolls off the assembly line at or close to the same spec. Furthermore, Jaguar and other OE manufacturers instill multiple redundant safety measures to make sure that the device does not land in a wrong gear. As your hot rod is different than my hot rod, the shift by wire concept gets lost in translation. The result is a clunky and potentially dangerous solution.
      Better to craft some sort of subtle, but human manual lever and cable system. We have customers who build upside down levers that tuck under the dash--similar to a modern hood release. Other simply cut down column shifter stalks and paint them the same color as the column so that they disappear. For his last build lil' John Buttera built a simple, but elegant lever that tucked between the driver's seat and console.
      PRNDL is a safety critical function. Go for a mechanical solution with good ol' human interface.
      Thanks for your interest in the Shrifter®
      /Steevo
      ________________
      Steve Chryssos
      Sep 2011
      Thanks for the info. I watched Inside West Coast Customs last night and they used the Master Shift push button shifter on Will.I.Am's '58 Corvette. Looked pretty cool.
      Norway
      New product !
      There is a new system coming from PCS.
      It can work together with a paddle shifter.
      Anyone know more of this?
      Arne A Hjemaas
      Nov 2007
      Belleville, MI
      Hi Guys, I'll be putting more info up on this in the next few days. Lots of good things coming in 2013 from PCS!
      Anyone using that system?
      Any info from PCS?
      Feb 2013
      Country Flag: Finland
      i have one Retrotek Smart Shift if someone needs one
      1970 1/2 Chevelle Convertible Twin Turbo SBC+4L80e +M9 , ridetech air suspension, custom frame,
      1968 Dodge Charger 572 all aluminum Hemi now with single turbo ,4L80e, dana60, XV-motorsports level II with some updates.
      Aug 2009
      Quote Originally Posted by studio57 View Post
      Do you still have this available?
      Feb 2013
      yep, i still have it.
      Edmonton, AB Canada
      Does anyone in the US or Canada have a Retrotek system that they want to sell? I need parts.
      Thanks!
      Grant Reierson
      Manager Capital Gear Motorsports -Canada's largest Detroit Speed Dealer
      Chevy High Performance Feature Article
      http://www.chevyhiperformance.com/fe...ova/index.html
      May 2022
      Long shot
      I know this is a REALLY old thread. Do you still have the shifter?
      Feb 2013
      I think i do but not sure if it works
      Quote Originally Posted by cmag2914 View Post
      Nov 2018
      It's not a push-button, but Dodge does have their knob-style shifter so it's different, and can be put anywhere. As far as I know it's interchangeable with their T-handle shifter so it should just be a switch with no internal programming. Might be worth looking into if the actual push-button shifter isn't available anymore. Jaguar uses a similar one, so it's likely a plug and play on a ZF transmission provided the donor uses the same transmission, would probably need some help working with any non-ZF units.
      2021 Durango R/T
      2005 Dakota beater
      2003 Dakota project-o-mobile
