    Page 2 of 2 FirstFirst 1 2
    Results 21 to 27 of 27
      Sort of :-/
      I see the outline for the inserts, but I still don't understand how you raised the perimeter of the panel and gave it such a nice edge. Was that just done with foam? If you look at the picture that you posted, look at how the carbon fiber looking material is raised up lets say at the area above the door handle trim.
      The perimeter is raised using 1/4" closed cell foam. The edge is simply just a very careful 90* cut with a fresh sharp razor blade. The outside edge was the same 90* cut, but it was sculpted, or carefully rounded using sandpaper for a smoother edge than a 90*.
      Mar 2010
      So I've probably read this thread about 50 times. Finally got the materials together & tried my hand at doing my upholstery in my 67 camaro. I took some styling queues from your build. Your step by step instructions helped tremendously. Mine didn't turn out perfectly but they look sweet. I'm also going to be doing the upholstery on my new kick panels with speakers & tweeters. Thanks!
      Nov 2011
      Livermore, CA
      Very cool , will have to come back to this later. Great write up!
      Livermore, CA
      American:
      1966 Chevelle SS "Tribute" Retro / Pro-Tour
      For Sale
      Dunwoody, GA
      This is a good write up. Thanks, Scott.
      Also, you mentioned covering the rest of the interior plastic in vinyl. How did that turn out? I've got to do something with the plastic in my car too.
      Trey
      ~ Jon Hammond
      Sep 2013
      Chicago suburbia
      I love that window crank! Where did you find that, if I can ask?
