    Results 1 to 19 of 19
      Oct 2005
      Toronto
      What do think this is worth?
      What do you think a 1970 Trans Am (currently "all" the right stuff is gone,,, basically a shell) is worth as a 1970 Trans Am pro-touring car..... Now understand the motor trans and rear is gone and the rest almost could be considered gone so it would consist of primarily Carbon panels and aftermarket/pro-touring parts :
      -Full carbon front clip (Hood, fenders, inner wheel wells, cowl panel etc etc)
      -new after market rad support
      -1973 TA sub-frame from my white car with Ride Tech strong arms and triple adjustable coil overs
      -1973 rear end from white car
      -Wilwood brakes on four corners (6 pistons up front and 4 out back)
      -70 400 stroked to 461ci with aluminum KRE high ports (new freshen up 0 miles)
      -Full 1970 Firethorne burgundy deluxe firebird interior (sorta red burgundy color)
      -4 speed Muncie 21
      -set of either Rushford live wires or stock KN Ralley set on BFG's if they clear the brakes
      The car would look like a stock-ish 70 TA paint scheme and we'd reverse out the carbon fiber for the edge of the stripes on the car.... So think White car with Blue and Black stripe in stock form,,,or in this case a White car with a clear carbon outer edge stripe and Candy Red to Bugundy fade on inside of stripes.....
      The interior would look stock and other than the color changes the car would look relatively stock-ish in nature overall....
      This would be all freshly done top to bottom,,, front to back,,, values????....
      Carbon Kustoms Limited
      A.K.A. Albert from Toronto
