    Results 1 to 15 of 15
      Eau Claire WI
      Speed-Tech vs. Ridetech
      Not trying to start a war here, just wanted some sugestions.
      I have a 67' camaro and want to keep the stock sub. I have thought of using the same ridetech's front suspension as the 48 Hour camaro OR using Speed-Tech's high clearence control arms and ther Chicane package along with RideTechs 48 Hour camaro front end?
      Lets here your ideas!
      Travis
      St George Utah
      Both good Choices, the Chicane kit lets you run a longer shock/spring , but there is some welding, We also have it set up for the ridetech shocks, the hiclearance Control arms (Uppers only) will work Grat on the stock sub BUT you will need the AFX tall spindle, The tall spindle helps corrects the steering as well as giving you the camber gain and Corvette wheel bearings and brakes.
      Currently we are working with RT to make the Truturn work with the AFX spindle, that will be the ultimate STOCK SUB set up.
      Blake Foster
      www.speedtechperformance.com
      435-628-4300
      St. George Utah.
      it's always sunny here.
      Eau Claire WI
      Thanks Blake,
      Would I be abe to run the ridetech spindle with the Speed-Tech arms?
      Would you say that the Truturn is even better than a power rack?
      Travis
      Cincinnati Ohio
      Im running ATS upper coil over mount, ridetech coilovers, DSE upper and lower arms, and ridetech Tru turn set up, Works great.
      I just had the 18x10's with 275's off brets 48 hour camaro, on the front of the nova at RTTH's and everything clears. Picked up 2 sec, too.
      1972 Nova Ridetech, Forgeline, Falken Tires, Wilwood, Bowler Performance Transmission, Lingenfelter Performance Engineering.
      Mountain View, CA
      Quote Originally Posted by killer69 View Post
      Does this address the issue we've previously discussed?
      True T.
      My blog
      Nor Cal
      Quote Originally Posted by Damn True View Post
      And what would that be? I have the AFX spindle and stock sub and am following this...
      1968 Camaro widebody project
      2004 Mustang LS2
      1964 Continental
      2014 Keezer
      Mountain View, CA
      On some applications (mine) it is difficult to fit a 9.5" wheel w/o impacting the outer tie-rod end.
      True T.
      My blog
      They both have "tech" in their names, how can you go wrong either way?
      Indiana
      The TRU TURN system WILL clear up to a 10" wide wheel with up to a 5.75" backspace in a 17" or 18" diameter. The Tru Turn steering arm is a bit shorter and higher, so it fits inside the bell of the wheel instead of hitting the rim edge. On a 67-68 Camaro with 1/2 height body bushings, a 275 tire will require a small amount of outer/inner fender massaging for turning clearance. stock height body bushings SHOULD eliminate this requirement.
      Also...this system will fit with NO tire clearance issues on a 2nd gen Nova. Apparently it has just a bit more room than the Camaro.
      As for fitment with the AFX spindle...I don't know that yet because we haven't had a chance to try it. I don't know that it WON'T fit...just need to mock it up. Hopefully after the Texas Goodguys event this weekend we'll get a chance to do that. We'll also get a chance to mock up the Heidt's spindle as well.
      I did have a customer, Prodigy Customs, that installed a Tru Turn with a previously done Guldstrand modification [lowering the attachment point of the upper control arm] and reported that installation to be successful.
      I also had a customer attempt to install a Tru Turn with a small block and large tube super comp headers...the header tubes interferred with the steering linkage and it was not compatible. He is deciding now if he will change headers or return the tru turn system.
      As for a rack and pinion conversions...absolutely NOT compatible. The systems that I have checked here have massive, undriveable amounts of bumpsteer, and I didn't see any feasible way to correct that. From what I can see, a rack could be made to work, but would require removal and replacement of the entire oem crossmember to get proper rack placement. Possible, but not really feasible. Remember with these rack systems...just because it will bolt on the car doesn't mean it will work.
      We will continue to identify combinations that may or may not work and try to keep everyone informed.
      Bret Voelkel
      Founder/ Former Owner
      How do you spell Impossible?
      Mountain View, CA
      Compelling stuff Bret. Thanks for the info. I shot you an email yesterday through the tool here on PT.com with a specific inquiry.
      True T.
      My blog
      Indiana
      Send me a direct email at [email protected]. My iPad doesn't pick up the pm's well.
      Bret Voelkel
      Mountain View, CA
      Quote Originally Posted by bret View Post
      It should have gone to your email, not your PM. Will re-send later today.
      True T.
      My blog
      Eau Claire WI
      Thanks for the advise given. Its nice that this site has people that are willing to give real world facts.
      Travis
      Suisun City, Ca.
      "I also had a customer attempt to install a Tru Turn with a small block and large tube super comp headers...the header tubes interferred with the steering linkage and it was not compatible. He is deciding now if he will change headers or return the tru turn system. "
      I have decided to have my headers modified to clear the inner tie rod. Pulled the header out, and started putting the passenger side back together last night.
      Mike
      Aug 2003
      Quote Originally Posted by mdprovee View Post
      Useless trivia information. My Super Comp headers on my 69 Small Black Street Racer are so tight that even with stock steering I cannot run zerk fitting on one inner tie rod because I can relieve the header enoug to clear a simple grease fitting. Piss pour clearance design
