      Miamisburg, Oh
      I need Muncie 4 spd help
      I've never messed with Muncie's before but recently picked up a freshened M20 (early) from a member to replace my old stock 3-spd manual. All my buddies are Ford guys so I have no knowledge what-so-ever around these Muncie's.
      I purchased a new Hurst Competition Plus shifter, part# 391-7308 and the Hurst install kit #373-3163. Research showed those to be the best chance of working, and today the Hurst 'Tech Line' (cough, cough) also confirmed those as compatible for my 1966 Impala.
      Here's my dilemma. Although my 1-2 and 3-4 arm-attachment points are SHAFTS, my reverse gear is a BOLT style. I'm not 100% sure if that is normal or if I may have a '69-later tail=shaft.
      The big dilemma in that is that my Hurst bracket for the reverse arm doesn't fit at all! It seems as if the slot in the bracket is a bit too short.
      Hurst tech-line was no help on that - does anyone have any insight about this situation?
      My other smaller problem is that the 1-2 and 3-4 brackets don't slip over the stud nicely. I was afraid to force it for fear of damaging the threads. Should I force it a little more?
      Pics coming....
      69 RS
      LS7, T56 and other cool stuff
      Back on track in late 2020!
      Build Thread
      Miamisburg, Oh
      the width of the 'male-slot' thing is .325", the length is about .725".
      The bracket seems to be about .315", and the length is about .625"! Like I told the Hurst guy, I'm about one-tenth too big here.
      EDIT: just talked to another Hurst guy to pass on these measurements. He said he has no record of any Muncie ever being anywhere near .7"+.
      PPSEDIT: Hurst guy also said he would send out new 1-2, 3-4 brackets with the extra clearancing in the centeror the studs. We'll see how that goes....<fingers crossed>.
      69 RS
      Build Thread
      Miamisburg, Oh
      So, I broke out the Google-Fu and searched for "Muncie transmission god". This ultimately let me to "David W. West of Davids 4 Speeds LLC". David answered and helped as best he could. He did say that the early and late style slots were different sizes so he felt my Reverse gear was probably just the later unit and I could use a 69-later bracket on it. (Why didn't Hurst say that!!)
      Option #2, which I've purposely not mentioned to anyone I've called, is to grind out the hole on the bracket with a Dremel or something.
      So, I think that is the option I'm going to take instead of waiting days for a part that may or may not fix this.
      Oh, and for the Forward gears, Hurst is sending me brackets with the center drilled out to clear the studs, free of charge.
      69 RS
      Build Thread
      Jan 2009
      San Antonio, Texas
      Best place I've found to get Muncie questions answered is at Team Chevelle forum in the transmisison section. Few pretty good tranny guys hang out there, including Jody Haag (Reading, PA, I think). Jody did a fantastic job on the M21 for my 70 Ram Air IV GTO. He not cheap, but d*mn good. You can find Jody with a google search.
      Check out my YouTube channel for vintage car and truck rescues and rebuilds! THE BULLETPROOF GARAGE!!! - YouTube
      NJ
      I had to grind out the shift brackets slightly to get them to fit on a super t10 with a Hurst shifter. Just had to clean them up a bit.
