      Sep 2011
      Millersburg MI
      Rear end advice needed
      Hi guys,
      Im putting together a pro-touring 1970 Lemans on a budget. I have the full hotchkis suspension including the extreme sway bar and the upper and lower control arms ( plus TVS ) The car had a stock 350 in it and I purchased a 425Hp 400 to install my question regarding the rear end is can I use the same rear end with a locker? its the original 30spline 12bolt with 373 gears. I have already bought the disk brake conversion and wasnt really expecting to buy the engine but it was for a good price so I picked it up. Now my concern is that I will have to replace the entire rear to accomodate the increase in power. Any guidance would be helpful
      Loganville, GA
      Is it the C-clip style (Chevrolet) 12-bolt? I believe so since it is 30-spline? If so, it will handle the 400 with no problems.
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
      Oct 2008
      Santa Fe Springs, CA
      Lemans70 – Thanks for installing Hotchkis suspension products on your Lemans! Do you have any images of your car posted?
      The factory 12-bolt is probably going to be fine for a while unless you’re going to be taking it drag racing with some slicks. It would probably help to install a heavy duty aluminum differential cover with the bearing-cap pre-load screws.
      Hotchkis Sport Suspension
      Toll Free: 877-466-7655
      Jun 2010
      Deployed
      No offense, but 400hp is not alot of power. Even a 10 bolt can easily handle that. Start approaching 600hp and consider welding the axle tubes to the housing.
      Mar 2004
      Mid-Michigan
      You have no worries unless you are going drag racing, with slicks, and 100% traction....
      What trans are you using? Probably a 350TH. Consider spending the money on a better trans (700R4) as the old 350 is going to be your weak link.
      Mark
      Mark:
      This my Bad Ast thread...
      This is my Fotki album...
      http://astroracer.fotki.com/
      Just remember that with street driving, the TH350 will probably last forever behind 400HP.
      For the record, a 1970 LeMans never came originally with a 12 bolt rear. Might want to double check to see exactly what you have.
