      Jun 2005
      baer rotor alternative....?
      Hello all!
      I have a rear baer kit with a 12" x .81 rotor with a lt1 caliper. Id like to decrease the rotor size to fit into a drag setup. Baer lists a 11.35 x .81" rotor as the next size down. Is this a stock gm rotor or a 11.5" camaro rotor thats been cut down? Cant find any answers. Id like to find a cheap rotor for mock up purposes.....
      Daren
      Loganville, GA
      A stock LT1 rear rotor should meet you needs, not sure if it is compatible with the Baer brackets though. You may need the stock GM backing plates from a 93-97 LT1 F-body or ones from Kore3.
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
