    Results 21 to 23 of 23
      Oct 2006
      Las Vegas, NV
      How much Nitrous can I run????
      Ok, for all of you NOS guys out there. I have a 69 camaro, 408 sbc stroker, running 10.6 to 1 compression, dart pro 1 heads, edelbrock rpm airgap, holley 750 DP, all forged internals. Have an aeromotive fuel pump (flows 150 gph) with an A1000 regulator set at 7.5 psi. Not exactly sure what the cam is although I do have the specs and will post them later. Also, this is a street car, 3.42 posi, tremec TKO 600 that will not see the track. Just wanted some extra power in case a tuner wants to challenge me on the highway!!!!!
      After speaking with some NOS experts and some tech personnel in the industry I am getting mixed answers. I was told by NOS (the company - holley) that I cannot run more than a 100 shot without running race gas. Then I spoke with NX and they said I could run up to a 200 shot on premium pump gas 93. However, I live in Vegas and the the premium gas out here is 91 so they recommended 150 shot would be fine even with running my compression.
      So the question is, who has the experience with N2O to know what is the correct answer? I know about running colder plugs, timing retard (which I will be installing the MSD timing retard box) and the other components that go along with it. I'm just trying to find out what is the max shot I can use w/o going to race fuel. I know you start off low and work your way up but I just wanted to hear from people with experience to give me an idea of how high I can go. Thanks in advance.
