    Results 1 to 13 of 13
    Thread: built 200r4
      Hayesville,NC
      built 200r4
      I have a 200r4 thats just been built with TCI master kit and TCI constant pressure valve body and a B&M 10" 2800-3000 rpm stall. Trans has about 1000 miles on it and shifts fantastic. I also have a new TCI 3500 stall . I have decided to put in a T-56 and need to sell this to fund that swap . I also have a 200r4 that was built by Performa Built a few years ago if you want to buy one to build . I have a little over 1000.00 in TCI parts alone and would like to sell the trans and converter for 900.00 . It's behind a sbc and in a 1981 camaro. I also have the 2nd gen factory shifter that has the detents for the OD and the P.R.N.OD.D.2.1.tag.
      Dec 2007
      Salem, OR
      The 200r4 has the BOP bolt pattern also correct? Is the B&M a lockup converter?
      Mike
      Mike R
      '66 Olds Cutlass Convertible
      '15 Challenger SRT 392 (DD)
      '72 Pontiac LeMans (wife's toy)
      Hayesville,NC
      BOP ? yes the converter is lock-up .
      Mesa, AZ
      BOP=Buick, Oldsmobile, Pontiac. The pattern is different than chevy. Im not sure whether the 2004r has both though.
      According to SuperChevy.com the 200-4r is a dual pattern transmission. It's BOP and Chevy. If I remember correctly, this is because it was used in all the RWD full frame cars that GM made in the early 80's. It was cheaper to produce a single case than to commission two individual cases.
      GeoffP
      68 Camaro - LS1/T-56
      Jun 2008
      Midwest
      Any idea how much HP the trans can handle?
      Hayesville,NC
      It does have the multi bolt pattern . I talked to TCI when i ordered the parts and told them I have a 550 hp small block that I drive like a rental car and they said it would handle it . My motor actually is closer to high 400 hp and it does great .
      Houston, TX
      PM sent
      Tu Ho
      Firebird V2-LS swap
      Jan 2010
      Somewhere out there
      Quote Originally Posted by GeoffP View Post
      200-4R's have 3 bolt patterns.
      The very early and very rare BOP only types aren't really seen anymore.
      Most are either the Multi-pattern BOP & Chevy or just Chevy.
      http://classicoldsmobile.com/forums/...tml#post259346
      Quote Originally Posted by slick72 View Post
      Unless a 200-4R has the billet input shaft it's not going to handle much more then 400hp if the wheels lock up.
      The billet input drum is ~$400 alone. Any builder who uses it will list a $400 part they put in the trans.
      Read Jakeshoes info a few paragraphs down.
      http://www.jakesperformance.com/200-...uild_Tech.html
      Hope this info helps. Good luck with the sale.
      Hayesville,NC
      I've run a mid 400 hp motor with 150 hp shot of NOS in a 3800 lb car with 4.10 gears with the stock shaft and had a 200r4 live almost 5 years . The death of it was my fault because i didn't get the TV cable adjusted correctly. The new TCI constant pressure valve body pretty much solves that now.
      marina ca
      how much for the shifter???
      Hayesville,NC
      hessdawg , I don't want to sell the shifter till I sell trans . Once I get it sold I will let you know on shifter.
      Jan 2012
      Dallas, Texas
      Did you ever sell this?
