    Results 1 to 18 of 18
      IN/MI border
      fuel pressure regulator?
      Have a 6.0 LS motor with Ricks tank (internal pump). Getting ready to run fuel lines but not sure where to go with a regulator??
      NJ/PA
      waiting to see what others have to say as Ill be in this boat soon. Also what regulator did you go with? Part number? Thanks Steven
      Apr 2004
      OKC, OK
      most used and simplest deal is a 98-05 corvette regulator and filter. you will need adapter fittings and those you can get from russell
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Jun 2010
      Deployed
      Quote Originally Posted by MuscleRodz View Post
      Do you know the part #? I need a regulator too for my 1978 camaro LS swap.
      1970 Camaro/DSE build
      Aug 2001
      Connecticut
      The filter has the regulator built in. Speedway has a kit with the an adapter fittings, works great.
      http://www.speedwaymotors.com/LS1-Fu...Kit,41791.html
      1962 Corvette 327-340hp stock
      1967 Corvette L79 convertible
      2006 Corvette Z06
      2011 Corvette GS convertible
      Jun 2010
      Deployed
      Quote Originally Posted by 68sixspeed View Post
      Thank you so much for posting that. I see so many old threads about alot of parts I'm looking for and they never have the part #!
      V/R Rob
      Jun 2010
      Deployed
      Do you know what the kit comes with? I see the filter/regulator is $30, but for $70 it looks like you only get 1 extra fitting for the fuel rail?
      Looks like the kit includes quick-connect to AN adapters for the regulator inlet and return, plus the fuel rail fitting.
      Jun 2010
      Deployed
      Quote Originally Posted by 68Formula View Post
      I may just buy the filter seperate...I hate blue AN fittings lol...
      Aug 2001
      Connecticut
      I called speedway and they entered the order with black fittings.
      You should only need the one extra fitting at the fuel rail unless you have an older ls1, most of the newer stuff does the return line at the filter and only runs a pressure line to the engine and fuel rail.
      2006 Corvette Z06
      Jun 2010
      Deployed
      I have an 02 f-body type of set-up. Looks like if all I need is that fuel rail fitting, I can get that for a few bucks at Summit. I would hate to spend an additonal $40 for some fittings I'm not going to use.
      Please correct me if I'm wrong here:
      I need this for the rail: http://www.summitracing.com/parts/RUS-640853/
      The filter
      and just the associated hose/AN fittings to plumb it.
      Aug 2001
      Connecticut
      You won't need the extra fitting from summit if you get the speedway kit, they give you 4 fittings with the filter/regulator, 3 for use on the filter and one for at the fuel rail push on. But if you are going to get just the filter, then you will need the russell fitting from summit, plus whatever other fittings or Dorman hose ends to connect to the filter/regulator.
      2006 Corvette Z06
      Dec 2007
      Carlsbad, Ca
      anybody know the flow rating? it looks like it comes with -6 fittings. anybody used this with -8 lines? i was just about to pick up an edelbrock 10 micron filter, but hadnt got to the regulator yet.
      Tim
      Build Thread Link
      Jun 2005
      Lynnwood Wa.
      Don't use those old style Russell fittings,
      This is the new style PN is RUS. 646110
      The new style has the threaded "U" lock ring.
      Oliver Shultz
      It's OK to giggle and snicker. don't laugh and point
      Oct 2010
      Santa Ana, CA
      any one have pics of this and how close to ur gas tank/fule pump did you put the regulator?
      Havii Gonzalez, OC Calif.
      68' MARO - UNDER FULL RESTO - LSX ect..
      Used to be known as stilo
      Dec 2007
      Carlsbad, Ca
      is this the only filter and reg you guys are running? running close to the tank or up front? dead headed into fuel rails with no return? it looks like russel makes the old style in -8 that will fit the reg. not sure about the new style.
      Tim
      Build Thread Link
      Jun 2005
      Lynnwood Wa.
      Russell offers the new style in both -6 and -8.
      Blue or Black.
      Oliver Shultz
      Aug 2008
      Iowa
      Look at my thread. I have all the part numbers for the filter and fittings you will need in black from summit.
      https://www.pro-touring.com/showthre...nc-fuel-system
