    Results 1 to 10 of 10
      Oct 2006
      McKinney, TX
      CHEAP Small block serpentine??
      Does anyone make a kit for an SBC that is CHEAP, and made for PS and ALT? I don't run A/C in my p/u and the bracket that is holding my p/s pump is from a 70's era C10 and it isn't aligning with the rest of my set up so it chirps like it is going out of style.
      The cheapest I found is on speedway (midmount) and it would require me to pick up a new waterpump and powersteering pump
      Total investment is 609 and change...
      Thats not too bad, but it still seems a little high considering this is a temporary setup to keep it running until I've got the Camaro done and can pro-tour it.
      btw, I'm anti chrome (unless it is inexpensive) I really don't care what it looks like, so if anyone knows of a good SBC junkyard setup I might come by, I'm all ears!
      it doesn't need to be a serp, dual v-belts would be fine...just a setup made to work with all components!
      Confucius says, "Choose a job you love, and you will never have to work a day in your life"
      My build Beast
      Aug 2011
      Clearwater/FL
      For a serp setup I'd look for a 5.7 or 4.3 vortec setup, assuming you have the holes in the heads of course.They are super easy to pull off with accesories attached!
      88 Blazer sbc
      05 300c
      Thought the last oi fthe Gen I SBC used cast aluminum brackets on that serp system
      Greg Fast
      1970 Camaro RS Clone
      1984 el Camino
      Beach Park IL
      If you got room for a long pump run this http://paceperformance.com/i-6255267...thout-air.html
      But if you want to do it really cheap just buy a decent power steering bracket from http://alangrovecomponents.com/
      Donny
      Jul 2010
      Sacramento, CA
      Best if you have the money for new. You can also use the setup from a 3rd gen camaro fairly easy, and it packages well.
      -James
      1974 Z28 SCCA C Prepared
      1990 Firebird NASA CMC
      1989 Civic Si SCCA STC
      Apr 2011
      Ewing, NJ
      They did. There were actually a few different set ups between car and truck and even different sets between 305 and 350 in some cases. There are idler pulleys available to put in place of the AC and smog pumps since not all models were equipped. There used to be a complete list of the different set ups and part numbers on Thirdgen.org but I can't find it any more.
      It is as cheap a set up as you will find, available in any junk yard.
      -Tim
      NJSPEEDER - Tim Mullaney
      New Jersey F-body Owners Association
      www.NJFBOA.org
      NJ's home for all owners, friends, and fans of Camaros and Firebirds
      Aug 2011
      Clearwater/FL
      Quote Originally Posted by NJSPEEDER View Post
      They did. There were actually a few different set ups between car and truck and even different sets between 305 and 350 in some cases. There are idler pulleys available to put in place of the AC and smog pumps since not all models were equipped. There used to be a complete list of the different set ups and part numbers on Thirdgen.org but I can't find it any more. -Tim
      Are you thinking of the tpi/tbi setups? If so then you are correct about there being several different variations. There is also the even later model vortec 5.7 and 4.3 setups that are alot nicer IMO. They are packaged alot tighter and use a newer (and I'm sure more effecient) compressor. Only problem I could see with the vortec setup is running tall valve covers as the compressor is now on top of the vc. I'm sure a notch in the vc would solve this though...
      88 Blazer sbc
      05 300c
      Huntington Beach, CA
      Go get the set up off of an 88-94ish extended cab GM truck.
      This is the cast aluminum accessory package people are talking about above. But the extended cab truck didn't require a smog pump because of the weight class and it had a cleaner bracket on the passenger side. Its better than the kit GMPP supplies IMO. It doesn't need an idler pulley in place of the smog pump like the GMPP kit or car based ones.
      Even better if you can find one without AC.
      I went to a junk yard a few months back and these trucks were everywhere!! You will also get the benefit of running the CS130 alternator which is far superior to the 10SI alternator most people have in the older vbelt set ups. Its easy to wire up the CS130 into a two wire alternator too.
      Oct 2006
      McKinney, TX
      Are the mount holes on the heads of the vortec and old-school gm's the in the same places?
      My build Beast
      Sunny Florida on the Suncoast
      Quote Originally Posted by absintheisfun View Post
      Yes the accessory bolt holes are in the same location on pre 1986 SBC and the later centerbolt valve cover heads.
      Stay in it till you see God....then lift
      Where patience fails, force prevails
      "When you're born, you get a ticket to the freak show. When you're born in America, you get a front-row seat." G. Carlin
      Stapp's Ironical Paradox...... "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
