    Results 1 to 9 of 9
      Nov 2010
      BB Chevy 454 Help
      I just purchased a running 454 out of my buddy's 73 pickup for 200 bucks! I am looking to build it for 500 hp/tq. My idea was to dissasemble, look at the bearings, cylinder walls, ect to see what machine work is needed. If it all checks out good, what would you guys recommend doing as far as machine work. I want to run the stock crank, rods, and pistons if possible. As far as heads go i know the stock truck heads flow terribly, so i want to upgrade the heads. Any reccomendations? Just lookin for some basic info and ideas. THANKS!
      Nate
      Jun 2010
      Oxnard,CA
      It depends on what truck heads you have. If they are the 781 or 049 heads those are the best factory ovals to have. You can install 2.19/1.88 valves and a quick cleaning of the bowl area should get the power you want. The factory crank can be kept but the rods should be checked if they are 3/8 or 7/16th bolt. If they are 3/8 bolt rods ditch them and get some entry level scats. 7/16th rods can be upgraded to arp bolts. Get rid of the pistons. The factory pistons only have 8:1 from the factory and wont make the power you want.
      Chris Lansford
      69 Nova that's never done
      Nov 2010
      The truck is a 73 Camper Special. It came with a 14 bolt rearend and a stick. On the casting you mentioned, are those the last 3 numbers in the casting? What pistions would hold the power. At some point i will run a 150 shot of nitrous. Thanks for the help. Also it is a 4 bolt main.
      Jun 2010
      Oxnard,CA
      Any good forged piston would hold that power. Just look for one with a 30-35cc dome. Yes those numbers I gave you were the last three numbers in the casting.
      Chris Lansford
      Nov 2010
      Thanks!
      Aug 2011
      Clearwater/FL
      Quote Originally Posted by CanyonKiller View Post
      +1 Large oval ports,
      9.5:1 compression, rv cam and air gap intake will do it. A friend of mine had this combo and it made over 500/500 on the engine dyno. I believe the cam was somewhere in the 460.460 range, had hypers for pistons too
      88 Blazer sbc
      05 300c
      Jul 2011
      Gerogetown ky
      ill sell my 454 to ya lol am goin ls1 an i dont need the 454 anymore. on the dyno at the wheels it make 426hp an 582tq an its set up for a 100 shot on nos if u would like that. Its out of a 2000 pick up truck 2500hd I got the motor with 0 miles an no intake. Its a turn key motor all u got to do is add power wire an fuel lines.. it comes with the bellhousing also. The motor now has about 13,000miles now it went on the power tour with no problems. just let me know send me a pm if u want.
      jason
      don't drive faster then ur angels can fly!
      Nov 2010
      Quote Originally Posted by 69blackwhss View Post
      jason
      LOL! I would love too have it but, I dont have the money. Thanks for the offer though! What would you need to get it off your hands?
      Mar 2010
      West Tennessee
      64impala - Check your inbox. Sent you a PM this morning.
