      TN
      Damage from back pressure on Master?
      Hello,
      I was wondering if back pressure on a Master cyl would cause damage. Pressures equal to another master cyl. on the same line. My thinking is the master would act like a slave and all the stress would go to the small retaining ring that holds the piston in. Is this correct?
      Thanks.
      Benjamin
      Benjamin
      Twin Dusters
      Beach Park IL
      I don't know, are you thinking hand brake?
      TN
      Yep, it would come in quite handy with some of the things I would like to do.
      Benjamin
      Twin Dusters
      TN
      No one? I was thinking about doing a Shutoff for the back line. Then using Having the handbrake usable. But it would be nice to be able to have all wheel brakes and the ability to use just the rears. I know I could just do a double caliper setup, but I was looking for some other way...
      Benjamin
      Twin Dusters
      TN
      I figured it out.
      Benjamin
      Twin Dusters
      Jul 2011
      Nashville, TN
      try using sand rail cutting brakes.
      -Dave
      Project George - '66 Ford Galaxie 500 fastback
      Working on interior, body and paint now.
      Forged 306/C4. Collecting turbo parts for TT setup.
      I have tons of 65/66 galaxie parts collected. If you need something, just ask! my wife will thank you.
      Beach Park IL
      Quote Originally Posted by Bjkadron View Post
      I figured it out.
      Well, don't hold out on us. can you use two master cylinders in the same system?
      TN
      Quote Originally Posted by zombiekiller View Post
      Pretty much..
      The answer is.. Yes and no.. You cant just run a T and put two master cylinders on it. But, if you hook the outlet line of one up to the inlet of another (that is designed for it) you can run them in series basically. Wilwood has some cylinders that work for this as I would assume others do.
      Benjamin
      Twin Dusters
