      Feb 2006
      Spring Texas
      Oil Pan needed for LS3
      I have a friend with a Heidts front subframe in a 69 camaro. It has the Rack and Pinion. The motor is a LS3. The oil pan hits the r&p before it lines up to the motor mounts. He added to the motor mounts but now the driveshaft angle is terrible and you can tell by looking at the motor it is tilted back.
      Cant bring the back of the motor up because the header flanges are hitting the floorboard.
      Does anyone know the correct oil pan to use? Other option is to modify his pan. The very front 2"or 3" is where it hits.
      The pan he has looks to have about a 2-1/2" sump in the front and it needs about a 1/2" sump in the front. Is there a LS oil pan like that?
      Mike
      69 camaro, 502 w/8-71 blower, street car
      http://s268.photobucket.com/home/pro...69camaro/index
      Walla Walla, WA
      Mike Kelcy - '68 Camaro with some stuff done to it.
      It doesnt show what the front sump is on a h3 pan but if it would work i do have an extra one i will let go. It does have a crack in it but easily repairable if that would help. I also have the pickup tube for it too. I can send u some pics if interested.
      Central Indiana
      I beleive the Mast pan would work...... I can get you one if needed.
      Huntington Beach, CA
      I will be taking off an LH8 pan that shipped with a crate motor I got soon.
