Results 1 to 8 of 8
Thread: At home Alignment?
07-07-2005 #1
Starting The Transformation
- Jan 2005
- Beaufort, SC
- 115
At home Alignment?
Any way to get the alignment "kinda close" as far as the caster and camber? I installed new bushings all over up front and new springs and shocks. The car is still a long way from street worthy, but I want to get the alignment close so I do not wear out the tires too bad moving it around or if I drive it down the road behind the house...LOL...
I can visually look at the car and see the Camber is off pretty far. I also have a ton of alignment shims. Any ideas?
'72 Chevelle- 4 wheel 12" Discs, Konis, Hotchkis springs (shortened an extra coil up front), 17" Cragar Soft 8's with 245's in front and 275's in back. ---STILL IN PROGRESS---
07-07-2005 #2
- Jun 2005
- Grapeview, Wa
- 169
Check out www.stockcarproducts.com under accessories. Or you could probably do a search for Longacre Racing Products on the web. They make a bunch of products for doing an alignment on any patch of level ground.
Tad
'73 Camaro RS in progress.
L-D 3-link (working on the front end, too), SCP spindles, Wilwood brakes. I'll be working on it for A WHILE!
07-07-2005 #3
