      Jun 2010
      Western Kentucky
      Power Steering Delete Options
      I just bought a motor that has this serpentine setup http://paceperformance.com/i-6255268...-with-a-c.html
      It has a power steering pump installed. I do not have power steering in my car now. I am not planning on installing power steering at this time but i may at a later date.
      What are my options to reuse this serp kit but delete the power steering?
      Can i loop together the in/out on the steering pump?
      Does anyone make an idler pulley for this?
      May 2011
      central Pa, USA
      can we get a pic of the belt arrangement? it may be that with a shorter belt you can simply remove the ps pump from the system or add an idler in a convenient location.
      Tom
      trailers are for boats and broke stuff.
      Jun 2010
      Western Kentucky
      I dont think i can just remove the pump, do to the belt routing.
      Does anyone make an idler to replace the pump?
      May 2011
      central Pa, USA
      why not?
      Last edited by grenade inspector; 08-05-2011 at 05:11 PM. Reason: deleted random html code I put in by accident
      Tom
      Jun 2010
      Western Kentucky
      That should work I think I was looking at it all crosseyed or something
      May 2011
      central Pa, USA
      lol, its cool
      Tom
      Jun 2010
      Western Kentucky
      I think I figured it out
      I think that I can remove all the components that build pressure from the inside of the pump. This will essentially let the pump "free wheel".
      Let me know if this would not last overtime.
      This is the inside of the pump with the reservoir removed.
      Removed the metal plate to the pump
      Removed the small metal blades that build the pressure
      I will leave this piece out when it is re-assembled
      I will remove this plug to allow fluid to just flow through, trying to eliminate any pressure build up
      I will re-assemble as shown in pic
      The spring and bolt will be left out when re assembled, allowing fluid to flow freely.
      Here are my questions????
      Do these to balls need to be drilled out? They set close to where the pressure line hooks up at.
      How would i cap off the reservoir inlet? Could a rubber hose be used with a clamp? Or should i remove the tube and weld up the hole?
      I would cap off the pressure outlet.
      Should I run the reservoir with or without fluid?
      Should the O-ring for the reservoir/pump be replaced? It doesn't show any damage, but I'm not sure if its reusable.
