    Results 1 to 20 of 27
      Apr 2010
      Chandler, AZ
      LSX Blower Setup
      Has anyone gone with a blower setup such as a Kenny Bell Roots style or anything else for an LSX?
      I started entertaining the possibility of a blower.
      70 Chevelle LS3 T-56 Whiplash Rushforth Wheels.
      Paint design by Jason Rushforth
      Dec 2009
      They're all over LS1Tech. Many say the LSX block is a better candidate for boosted applications...
      Ron in SoCal
      69 Camaro in progress
      Used to be known as flash911
      Ramona, Ca. San Diego area
      I have a LS2 with an f2 im building.
      Had a KB before I went with the F2.
      67 Camaro convertible (Jinx)
      Aug 2003
      This is the hottest thing going in Blowers for LS. This is a special MaganCharger combined with a special modified version of our popular Wegner front drive. The very best for many reasons all related to belt type, belt routing, belt wrap. The blower is driven by it's own 10 Rib belt with over 180 degrees of belt wrap which prevents hated belt slippage commonly associated with blowers. Especially important in blower cars that are autocrossed and road raced with quick on and off the gas situations.
      When you combine the OEM quality of MagnaCharger the the very best front drive, it is the clear winner.
      Miami
      Sep 2008
      these pics look familiar Frank, well this is the direction I am going, I wanted something I could drive around town and have something I could beet on at the track, Frank has my setup at the dyno shop getting tuned,............lets see some numbers!
      Apr 2010
      Chandler, AZ
      Thanks for the info as I'll need to do a bit more research.
      Frank I have a L92 motor, Texas Speed Cam, LS3 Intake which won't be needed, Corvette accessories and the Vintage Air/Quick coonect I purchased from you. Will I need accessories be needed as well if I go down this route?
      Based on the accessories and the L92 heads are there other bloweres that would also work?
      Thanks!
      Apr 2010
      Chandler, AZ
      Quote Originally Posted by 67 ls1 vert View Post
      What made you change directions away from a KB? I had the KB 2.8H on my Saleen Cobra that was a moster of a blower.
      Quote Originally Posted by AZSaleen04 View Post
      I changed direction because of the computer tunning. I am using a carbed set up now with a blow through. Very simple set up using the MSD 6010 box that controls the ignition, cam, crank, tunning.
      Apr 2010
      Chandler, AZ
      Got it nice setup.
      Enfield, CT
      Ok Frank.
      How much?
      '67 GTO - LS3, 4L60E, SC&C AFX Package, KORE3 C6 Z06, Boyds PT-09s
      https://www.pro-touring.com/showthre...7-GTO-LS3-Swap
      Enfield, CT
      And what kind of coil brackets are those?
      DE
      I'm doing a mild setup with a Vortech T-trim. LS2 bottom end (stock) with LS3 heads and a custom cam. Blower bracket is for a Corvette, with Corvette accessory drive. Still got a way to go....
      69 Camaro - G-link, 12 bolt Moser, Speedtech CA, Iforged wheels, LS2, 6spd, etc. etc. In-Progress...
      www.fquick.com/jim98ta
      Apr 2010
      Chandler, AZ
      Quote Originally Posted by Jim98ta View Post
      I have the L92 heads on mine. Are the ports the same on a L92 and LS3? If so then I guess a Corvette setup would work.
      Central Indiana
      Ok.... Mike.... What are you up to now?? LOL.. To answer this question, Yes... the L92 heads have the same ports as the LS3
      Central Indiana
      Wow! That looks really nice Jim. Do you have a build thread going?
      Aug 2003
      Quote Originally Posted by CFster View Post
      Ok Frank.
      How much?
      Complete Blower and Drive System is $8800. Keep in mind the kit includes the front drive which includes A/C Compressor, Alternator, PS Pump, ATI Balancer.
      We can also set up the MagnaCharger blower with LS3 Accessories but the net savings is not to much unless you already own the LS3 accessories
      Aug 2003
      We have those also from Wegner
      Aug 2003
      Yeah, exactly. L92 and LS3 heads are exactly the same except the valves are hollow on the LS3 and solid on the L92..
      Enfield, CT
      Quote Originally Posted by ProdigyCustoms View Post
      I already have a C5 accessory kit. My compressor is on a Kwik bracket. Would that work?
