    Results 1 to 11 of 11
      Sacramento, CA
      '68 Nova LS1/T56
      I'm putting the Nova up for sale as I just don't seem to drive it much. I'm starting a new business and have no time for the car right now. It's a fun street car that always attracts a crowd at shows. It's turn key reliable and ready to race or just take out for ice cream. The car can be converted back to PT with a wheel change and a shock adjustment. I've had 17x11s on it with 315s and think the car can swallow a 335 if you were careful with backspacing. The 6 speed conversion and new 9 inch have less than 500 miles on them. The trans has 50K on it and has been a great upgrade, making the car more versitile. Looking for $26K. Here's the specs:
      1968 Nova
      Body
      -Finished in Lemans Blue PPG base/clear with semi gloss black Baldwin Motion style stripes bordered in vintage white
      -started with completely rust free body with all original sheetmetal (aftermarket steel 4 inch cowl hood)
      -New door and hood hinges
      -All panels gapped perfectly- doors and trunk shut with minimal effort
      -Newer vinyl top with new stainless trim
      -Detroit Speed minitub kit installed- trunk finished with factory style look
      -S&M race cars 8 point cage with camera mount- custom floor plates
      -New mirrors, emblems, door locks, etc
      -Paint is in excellent shape with some minor flaws- far better than driver quality- car is shown and does win paint awards
      -Entire floor covered in Fatmat sound deadener
      Chassis
      -QA1 adjustable front billet coilovers
      -Addco 1.125 inch sway bar with urethane mounts
      -SSBC front brake kit- slotted rotors and billet calipers- Wilwood billet master cyl.
      -Unisteer manual rack and pinion steering system with polished stainless link kit
      -New urethane bushings, new ball joints, wheel bearings etc
      -Competition Engineering subframe connectors
      -Inboarded Eaton Detroit leaf springs using Comp engineering rear mounts
      -Custom rear shock mounts with Comp Engineering adjustable shocks/ custom lower shock perches for optimal shock angles
      -Custom traction bars with adjustable links
      -Custom ordered Currie 9 inch rear diff. with 5 inch narrower track to optimize DSE kit (gives more wheel options and a far wider rear lip) – spine braced, filler cap, drain, vent
      -new Strange Pro-G nodular third member
      -new Detroit Locker, Richmond 4.33 gears
      -new 35 spline Moser axles, new bearings and seals
      -Centerline Telstar billet wheels- 15 x 7 (new 205/60/15) and 15 x 10 (Mickey Thompson 325/50/15 Drag radial) The car can run an 11 inch wheel and a 315+ tire. The custom narrow housing allows for a 6 inch deep rear lip.
      Engine
      -2003 LS1 (all aluminum)
      -TEA ported heads
      -Autokraft oil pan
      -Edelbrock motor mounts and coated headers
      -Thunder Racing Trex 2.0 cam (242/248 .608/.612 110 LSA)- new LS2 timing chain-matched valve springs, locks, Ti retainers etc
      -Thunder Racing new ported and polished LS6 oil pump
      -Comp Cams Heavy duty pushrods
      -6.0L heavy duty Coil packs and Taylor plug wires
      -Edelbrock victor intake manifold and custom Holley HP 750 carb built by Competition Carburetion of Nevada
      -MSD 6010 timing controller with easy to use laptop software, custom billet bulkhead harness plate
      -2.5 inch exhaust with 3.5 inch electric cutouts, Bullet mufflers, X pipe, and over the axle terminating under the bumper tailpipes
      -Meziere billet electric water pump with in-car adjustable speed controller
      -Holley blue fuel pump- (-8 delivery line, -8 to carb, Holley reg. with gauge, -8 return line,20 gallon aluminum cell with AN beathers and sump)
      -Custom ordered Griffin radiator with 1.5” tubes (-20 AN water lines, 1600 cfm fan) car runs 175-190 on even the hottest days in traffic
      -T-56 trans with Hurst billet shifter
      -new Monster level 3 clutch
      -new Billet steel flywheel
      -new ARP hardware
      -new Custom tubular trans crossmember with drop out center
      -new Quicktime SFI scattershield
      -new brand new steel driveshaft by Driveline service with all 1350 Spicer joints
      -Custom billet capped center console/ Lokar boot/ Hurst pistol knob with line lock
      Interior
      -New door panels, hardware, and dash pad
      -Custom built gauge panel with billet gauge surround, billet control panels, Autometer gauges and tach
      -Corbeau race seats, G force 5 point harnesses, custom rear bulkhead panels and package tray
      -New headliner and mirror
      -Painless wiring harness
      -Lecarra steering wheel
      A couple things to fix- gas gauge and volt meter went on the fritz last week. Could be a ground. One of the cutouts has decided to no longer open. All will be fixed before it leaves my garage. The weakest areas are the carpet and a couple tiny spots in the paint that you wouldn't notice unless I pointed them out.
      walk around video when it had the auto in it: http://www.youtube.com/watch?v=w0dL_VBNqEI
      Dave Smith
      29 Ford Roadster Pickup blown 327 and stupid
      67 Chevelle 396/5 speed PT
      65 El Camino L79
      alpine ca
      such a cool car Dave good luck
      john
      BUILD LINK
      Sacramento, CA
      Thanks John. I'm hoping it goes to a good home. It's been fun. The latest mods made it far, far better.
      Dave Smith
      65 El Camino L79
      Sherman Texas
      Do you have any more pics you could send me [email protected]
      -Thanks John
      John Ray
      Birmingham, AL
      I have always liked this car. Such a clean engine compartment.
      Stephen
      Sacramento, CA
      Pics sent to John.
      Thanks Stephen.
      Dave Smith
      65 El Camino L79
      Northern New Mexico
      Love the car, love the color, love the sound! Good luck with the sale.
      Paul Viramontes
      Sacramento, CA
      Quote Originally Posted by PSV View Post
      Thanks Paul! I think you need an LSX Nova!
      Dave Smith
      65 El Camino L79
      Mar 2010
      Alabama
      I would love to have this car. I have a 79 z28 that has the exact same wheel setup but it is bbc with spray no lsx but I wish. haha If I had the cash i would be all over this car.
      David Butler
      "If you're not first, you're last"
      67 Camaro Twin Turbo SBC (changing from Blow-thru to Holley HP EFI)
      Sacramento, CA
      car is sold.
      Thanks guys- thanks PT.com.
      Dave Smith
      65 El Camino L79
      Sep 2011
      Las Vegas,nevada
      Thats a neat lookin hood stripe.
      I live my life a quarter mile at a time cause for those 10 seconds I don't have a care in the world.
