    Thread: Pinion angle
      SoCal
      Pinion angle
      Ok, I've been studying the pinion angle threads and I'm still confused. My measurements are:
      drivetrain angle pointing 1.4 degrees down (measured by bottom of oil pan)
      rear end pointing 2.2 degrees down (measured across face of rear end housing perpendicular to ground
      So is my pinion angle -3.6 degrees?
      Some more measurements that may or may not have any bearing:
      driveshaft is 3.1 degrees down towards rear of car
      ground sloping 0.3 degrees towards rear of car
      Nov 2004
      Roanoke, VA
      My post made absolutely no sense after re-reading it and I managed to confuse myself so I deleted it. Hopefully someone that knows will chime in and help us both.
      "....lets see...1 deg down + 3 deg down equals...no that doesnt look right....scratches head... "
      GMC Syclone (currently wrecked thanks to the typical rubber headed VA driver not paying attention to his red stop light...oh and he didnt have insurance either)
      #614 11.9 @ 113
      New stuff finished 08/06:
      4L80E trans w/TCI PCM
      Syclone
      Tow rig
