    Results 1 to 20 of 33
    Thread: Ls376/480
      Jun 2002
      Santa Clarita Cal,
      Ls376/480
      What would you do to a new LS376/480 motor to increase the HP and torque a bit, maybe just a different cam and FAST intake? I have been looking at 418 strokers from some vendors but am a little short on cash! Would I need to upgrade rod bolts also?
      Thanks for any info!
      RSK68
      Rick Klein
      Huntington Beach, CA
      Hey Rick,
      Have you seen this article? Its two years old but should give you some ideas on what a cam change can do for power in an LS3.
      http://www.gmhightechperformance.com...son/index.html
      Jul 2003
      Anaheim Hills, CA
      An LS3/480 already had a bigger cam than an LS3.. something like GM HotCam.
      And that number is low.. on a engine dyno, with long tubes it's way over 500hp. You could go with an even bigger cam and maybe have the heads massaged.. but in that case just buy an LS3 since you're paying extra for the larger cam/springs.
      I have one sitting in the shop waitin to go into a 71 Chevelle wagon..
      1968 Track Rat Camaro:
      Aug 2003
      We talked about the 418. Just do one of our LS3 / 540HP instead of the 418 Rick With forged pistons is only a few hundred more then the 376 / 480HP and with forged pistons you can force induction it later or spray it with NOS!
      If your really considering LS3's, keep in mind that our motor already comes with a $425 road race pan to fit first gens and A Bodies, so the cost is technically the same as the 376 / 480.
      Jun 2002
      Santa Clarita Cal,
      Frank I have been trying to do all the math and I still may be coming your way, ill PM you.
      RSK68
      Rick Klein
      Jun 2002
      Santa Clarita Cal,
      Pulled the trigger today on the LS3 from Frank at Prodigy, Thanks frank!
      RSK68
      Rick Klein
      Dec 2009
      Welcome to the dark side Rick! You're gonna make a great car even better...:thumbs:
      Ron in SoCal
      69 Camaro in progress
      Used to be known as flash911
      Mar 2002
      North California
      Quote Originally Posted by rsk68 View Post
      Same engine I have Rick, though Iam still selling old parts,and need a 4L60E trans to finish and get the damn car running before the end of summer ( I hope) But don't worry, I went for a test drive in a buddy's car with the LS3 and all he did was add some headers and a full exhaust, all I can say is the power is scary in these engines and it pulls hard! I hope to find out for myself soon lol..Congrats on the new bullet!
      Aug 2003
      Two long weeks Rick.
      Rick got this one
      Aug 2003
      She is on the way Rick, Ain't she purdy!
      Dec 2007
      British Columbia, Canada
      Aug 2003
      That is our Wegner Drive
      Here is another better view of the front drive
      The belt wrap is the best in the industry with special attention to the PS which is a BIG issue with fat front tires.
      Jun 2002
      Santa Clarita Cal,
      Very nice Frank, thanks for everything!
      RSK68
      Rick Klein
      Aug 2011
      Michigan
      That thing is MINT!
      Jun 2002
      Santa Clarita Cal,
      fuel rail mod
      Been making some progress on getting this into the car, today i modified the fuel rail to us a AN fitting, i didnt like the snap on OEM type.
      RSK68
      Rick Klein
      Eastern Virginia
      How did you add the AN fitting to the fuel rail? I like it!
      Scot
      86 Monte SS
      Jun 2002
      Santa Clarita Cal,
      I took a 3/8 pipe to 6an fitting, machined the pipe threads off and bored the hole to fit the rail then had it brazed on.
      RSK68
      Rick Klein
      Dec 2007
      Carlsbad, Ca
      one of the mags just showed the fitting to go from push to an, but it doesnt eliminate the push part. i like what you did.
      Tim
      Build Thread Link
      Jul 2011
      Stafford Va
      keep it going I plan on ordering one in Feb, just not sure if it will be the LS3/540hp or the 418 620 Carb
      Eastern Virginia
      Where did you find the original part? I've been looking with no luck, did you use stainless? Want to make another one, what would you charge me?
      Scot
      86 Monte SS
