      SoCal
      door hinge springs
      How do you get the little spring back into the bottom door hinge? This thing is driving me batty!!
      Nov 2004
      Roanoke, VA
      The spring that engauges the hinge pin and the stepped rocker looking thingy (the spring that holds the door open)?
      If so then there is a tool you can buy for a couple of bucks to install it since using screwdrivers or pry bars to get it in there will only launch the spring accross the garage or into your forehead.
      Found this by searching for "auto body tools" then searching for "door hinge spring" in the tool section.
      http://www.toolsusa.com/cgi-bin/sgin...32062302075856
      GMC Syclone (currently wrecked thanks to the typical rubber headed VA driver not paying attention to his red stop light...oh and he didnt have insurance either)
      #614 11.9 @ 113
      New stuff finished 08/06:
      4L80E trans w/TCI PCM
      Syclone
      Tow rig
      SoCal
      Wow....finally got one in! Used a C-clamp, Vise, and several tubs of petroleum jelly... don't ask...
      Classic Industries sells the spring tool you are looking for.
      NY
      Eastwood sells it too #31202
      The needs of the many outweigh the needs of the few.
