Thread: Lower A arm ID for F-85
07-10-2011 #1
Hi guys just signed on the site. I am currently building a 64 F85 post "bare bones granny car" I have a ton of pictures on this project so far that I will post. The Issue today is please look at the attached pictures of these lower A-Arms. They appear to be UMI's but not sure. My problem is these will not work with my B-spindle/I-ROC 1LE brake upgrade. The lower ball joint will not seat enough to get the crown nut all the way on. I think the taper is different for a B-spindle ball joint, than a A-spindle lower ball joint. Question is if these are indeed UMI control arms can I buy MOOG or whatever B-spindle ball joints and have them pressed in or is the lower control arm shaped different? The upper arms are totally different. Notice the shock hole is routed out to fit the QA-1 shocks. The holes for the shock bolts are now very close to edge of the routed out shock hole-also makes me a little concerned. Thanks.
