      Feb 2011
      !!!!turbo 350 problems please help!!!!
      just installed a 350 trans on my 72 chevelle and put the car back on the ground and park seems to work but all other gears the car only rolls forward even in neutral wont roll backwards and no i didnt try this with the car running im still building the car and doesnt run yet, the trans i got from my father and he got it from someone online and the guy said it was all rebuilt and it looks that way to from what i see, also i didnt put any fluid in it yet either so the trans has been sitting for at least 3yrs with no fluid, a few people told me to put fluid in it first and see what happens, but i would of thought it would at least roll backwards in neutral fluid or not. i also checked shifting linkage and brakes and rear end and nothings wrong there, if anyone has any thoughts please help thanks
      Jun 2011
      Vette City, USA
      Quote Originally Posted by PIMPCHV View Post
      That makes no sense to me. Without a spinning pump, the transmissions is basically just extra weight if it isn't in park. I can push my car around in the garage in any gear but park if it isn't running. Without fluid pressure it just doesn't work, period.
      Are you sure you don't have a parking brake, a wheel chock, slight grade or something else going on because I patently haven't seen that in any automatic I've ever been around.
      Old enough to know better, young enough to think I can get away with it.
