    Page 1 of 27 1 2 3 4 5 6 11 ... LastLast
    Results 1 to 20 of 536
    Thread: Project 70 RS
      Feb 2009
      N.J.
      Project 70 RS
      After having the car apart for alomost 4 years, things are starting to come together.
      Subframe and engine are back in it actually feels like I'm getting somewhere.
      There are too many members to thank for all the help I have been given, so I will just thank all the people on this forum.
      Here is a before picture of the engine compartment and an up to date picture of the progress so far.
      Thanks again for all the help.
      Feb 2009
      N.J.
      Project 70 RS
      Here is an interior picture the week I got it.
      Completely gutted and alot of useless wiring but rust free.
      I'm in the process of installing the Vintage Air system at the moment.
      Everything inside is new including a lot of Dynamat.
      Here is a photo from last week.
      Jul 2010
      Rancho Murieta
      wow, lots of progress, car looks great! Need more pictures though! btw, what color is that that you painted the engine with? is it cast iron? I'm lovin it!
      Feb 2009
      N.J.
      Thanks Clutch93,
      Yes, it is cast coat iron. It will look awesome with all the stainless steel arp hardware I have for it.
      I'm going to try and post some more pictures this weekend.
      I should be getting my headers back from the ceramic coaters on friday.
      I want to get the rest of the engine together this weekend so I can finish the Vintage Air install.
      Thanks again
      Feb 2009
      N.J.
      I recieved some parts from Anvil Auto today.
      Radiator closeout and aluminum fender braces.
      Nice stuff, can't wait to put them in.
      Closeout will be painted low gloss black just like the rest of the engine compartment.
      Really makes the engine pop.
      Feb 2009
      N.J.
      Picked up my headers from the ceramic coaters today.
      Hope to get them installed tomorrow so I can put the a/c compressor in too.
      Also here's a better picture of the interior.
      Jun 2011
      Ohio
      Man that interior looks really nice!!
      Feb 2009
      N.J.
      Thanks, heres a picture of my dynamat stage.
      I went a little crazy with it. Got a great deal on ebay and bought more than I needed.
      Ended up doing the insides of the doors too.
      They close like a new car though. Love that solid sound and feel.
      Jun 2011
      Ohio
      Looks great should keep the noise level down.
      May 2011
      Central FL
      The interior looks great, very clean. Was there originally any wood laminate on the inside? I can't stand the stuff lately.
      - David
      1967 Camaro - In remembrance of my friend Scott
      Feb 2009
      N.J.
      Not really sure. When I got the car it was pretty much gutted.
      All the A pillars and anything that was gloss are painted a trim black now.
      All metals are a brushed finished now also.
      Trying not to have anyhing shiny.
      Here's a picture of the front subframe before and after coating it with KBS
      3 weeks ago.
      No shine.
      Mar 2010
      Clovis NM, 88101
      Brother, it is looking good!! Keep the pics coming and don't stop working on it.
      73 Camaro
      Gene
      Its looking great. Nice job on the subframe.
      Feb 2009
      N.J.
      Thanks, I am really happy with the satin look of it.
      It makes the engine stand out even more.
      Well, I have to go put the headers on.
      More pictures later.
      Feb 2009
      N.J.
      Just got the headers in and now have to go get stainless steel hardware to bolt them to the exhaust. Have aluminum gaskets for the collectors but did not like that the bolts were not s/s.
      Installed the Vintage Air compressor. Brackets are ok but definitly look better with arp hardware.
      Feb 2009
      N.J.
      Started early today, hooked up the trans linkage, trans kickdown, throttle cable.
      Installed the new OER dash vents and v/a control panel.
      Connected the headers to the exhaust.
      Mounted the radiator support and started fitting the new aluminum rad.
      that's been sitting in the basement for almost 2 years(about time!).
      Then had time to barbeque and enjoy the day.
      Here are some pictures of the dash wiring and covans dash insert with Autometer guages.
      Its looking great. Nice work.
      Jun 2011
      Ohio
      sounds like you had a busy 4th looks great!
      Feb 2009
      N.J.
      Thanks guy's, it was a great day.
      Worked on the car AND had family time.
      I have been mocking up the radiator and have run into a snag.
      I was going to keep the original fan shroud but once I put in the aluminum rad, the
      shroud really looks crummy.
      So, I have been looking at some nicer alternatives.
      What do you think of this?
      http://www.jegs.com/i/Flex-a-lite/400/536288/10002/-1
      I have never used electric fans before on my projects and I'm not sure.
      Feb 2009
      N.J.
      Decided against this particular setup. Just found out the fans are only 700cfm each.
      Seems kind of weak.
      Will have to keep looking.
      Here is picture after I installed the headliner.
      I think it came out pretty good for my first time. Followed the advice of several other members.
      The info on this forum is invaluable to doing things correctly.
