      Feb 2011
      Cold Air HP Gains??
      I have had a idea for a while now, so googled it to see if anyone else had done what I was thinking and found ONE!
      here it is... air to intercooler to carburetor = HP???
      I am not talking about a cold air intake you buy a pep boys
      I mean a real intercooler to carburetor set up
      do guys think it would make some power
      cause engines run better with ice cold air or so they say
      Midwest
      Well... seeing that carbs rely on the engine vacuum to pull air into them, I would think an intercooler on a non-forced induction system would be a huge restriction in the air intake path and would probably crush performance.
      Also, forced induction systems create heat in the intake charge with the compression process, and the intercooler helps remove that heat. But carbs breathe ambient temperatures. An intercooler (air to air) relys on ambient air to cool the charge, so you would not be cooling the air charge very much.
      Kevin Oeste
      V8 Speed and Resto Shop
      V8TV
      Muscle Car Of The Week
      V8 Radio Podcast
      All about us:
      https://www.v8speedshop.com
      Loganville, GA
      Wouldn't it be better to just duct cold air to the car, like they did in the 60s? Much simpler and cheaper.
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
      Apr 2011
      Ewing, NJ
      For an NA engine it is more about making the most air possible available to the engine. Cooler temps are nice, but the easier it is for the engine to draw air the better. That's why you see NHRA stock guys running the biggest air cleaner that fits or none at all.
      -Tim
      NJSPEEDER - Tim Mullaney
      New Jersey F-body Owners Association
      www.NJFBOA.org
      NJ's home for all owners, friends, and fans of Camaros and Firebirds
      Belle Plaine, MN
      Agreed. You're better off feeding fresh outside air to a carb than trying to route it through something that'll inevitably restrict its flow.
      Scott Parkhurst
      May 2011
      central Pa, USA
      I agree with those gentlemen ^^
      cooler air, if you could get it would be better, but hp alone only matters on a dyno, its power to weight that matters on the street.
      Tom
      trailers are for boats and broke stuff.
