      Clinton, IL
      1st Gen Help? Where does rear harness run?
      I am re-installing the rear body harness in a 1968 Firebird. It has been apart for a very long time. I can't figure out how/where it routes as it passes next to the lower back seat in that run channel - where/how does it go up over the wheel housing to the trunk...and where/how does the dome lamp harness run to the roof?
      Chris McDonald
      Apr 2004
      OKC, OK
      harness passes through gutter under door, then goes up and over the outer wheel house. there is a clip at the rear of the wheelhouse which is also where the dome light connection is. then routes over to trunk drop off for the marker light then on to the rear tail panel
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Milwaukee, WI USA
      Dome light harness runs behind drivers side sailpanel to light...
      1969 Camaro SS, 350(NOM), M21, 12 Bolt Posi, 01B (Jan 69) LOS Build
