Thread: EZ Idle Issues
06-22-2011 #1
- Jul 2010
- Maryland
- 8
EZ Idle Issues
The ez fuel injection started out working fine, then started having issues with acceleration and not getting fuel which turned out to be bad fuel pump that they replaced. Got new fuel pump reprogrammed and runs fine on initial drive. When I restart the car it is hard to start and seems to search for an idle. I was told to check the IAC and make sure it was below 20. The IAC is below 20 when I do the initial drive after adjusting the blades and don't cut the car off. Once I cut the car off it starts searching again. Tech line said to adjust the blades during warm up and it keeps the IAC below 20 until I cut the car off and attempt to start it again. I have change the distributer springs, checked for exhaust leaks, connections tweaked the blades after driving it still does not work. If anyone has any suggestions please help.
