06-17-2011 #1
Routing Cage in 70 mustang (ideas needed).
Just started my cage in my 70 Mach1. Since I will be replacing my roof skin I have an opportunity to make this cage an extremely tight fit. If possible I would like to keep all the vents, heater ac etc. I also want to run the cage through the dash so I can keep theinterior as opened up as possible. Here is where I hope some of you mustang guys can help out. I want the front part of the cage to run as close to the A pillar as possible and then tie into the torque box. if I do this the bar will run right in front of the kick panel vent making it impossible to remove. I could restore these peices and install them permenently hoping that they never have any issues, or try to route the cage differentely, or delete them alltogether, which I would rather not do.
Just curious if any of you have encountered this, or have any thoughts on the subject.
thanks in advance for your input.
Zach
06-26-2011 #2
- Dec 2010
- 708
I'd think over what you really want to do with the car, then check out info on what racing/sanctioning bodies (NASA/SCCA) require of cars that are expected to crash violently in competitions. After doing this, you'll see that a lot of cars have very expensively built cages that would be laughed away from a real racing event/competition, due to illogical bar placement. Always remember the main hoop behind your seat as the starting point, then think of the doors crushing, the roof crushing, and how long a tube (especially a bent one) can reasonably be before it no longer has any practical function. Learning a lot of this stuff annoyed the hell out of me, but it also made some things simpler in the plotting of my roll bar install. I do not plan on competing anywhere; I just want functional equipment (and I like the look of pretty scaffolding). Cheers.
06-27-2011 #3point well taken. I think I am in a similar position to the on you are in. I want a functional cage so that i can pass tech inspection for open road racing, but this will also be mostly a street car that won't see much, if any wheel to wheel competition. My intention is to build something structurally sound with plenty of triangulation and as few bends as possible. I have no problem cutting up interior peices to fit around my cage, but I also don't want to lose the function of the few comforts the car has left and I see the kick panel vents as one of those.
1 3/4 .120 wall DOM isn't light so If it isn't serving its purpose as an efficient crash protection structure I don't even want it in there. so I'll have to get clever with this one. I'll try post some pictures so everyone can see the interferrance issue I am trying to avoid.Zach
06-30-2011 #4
