- Jul 2006
- El Paso, Texas
- 411
Another brake squealing problem!!
Hi all, I am having an issue with a newly installed setup on a 55 2 door sedan. Everything is brand new and is as follows: Hydraboost setup from ABS Power Brakes, CPP chrome master cylinder with built in proportioning valve, front 12" disc brakes with single piston iron calipers (standard mail order conversion kit), and C5 rear disc conversion using Kore3 brackets.
I just started putting some miles on it to get everything worked out and it has run fine for about 150 miles. Then suddenly the other day I get a massive squeal when I put a light foot on the brakes. It sounds like when you blow into a Coke bottle. Kinda like a loud humming sound rather than a squeal. Reminds me of a school bus. If I stomped on the brakes it would stop. Then I did a couple of hard stops and the sound went away for a while and then returned. And it only did it after 20-30 minutes of driving. I parked it for 10 minutes and it worked fine for another 15 minutes and then started again. And then it got worse. It started making the noise as I was driving with NO brake application. If I stepped on the brakes kinda hard, the noise semi-stopped.
So for now I parked the car. I took the rear wheels off and there is brake dust everywhere on the rear. I haven't checked the temps with a temp gun but that is my next step. I did try adjusting the prop valve per the instructions from Classic Performance Parts but to no avail. I read some threads here on the board and I'm thinking maybe it's a brake rod issue but I don't understand why it seemed to pop up suddenly. I am going to try loosening the master cylinder bolts and add a washer between them and the hydroboost to see if that helps. Am I headed in the right direction? Any suggestions would be greatly appreciated. Thank you guys.
Alex
