Results 1 to 18 of 18
How Does This Idea Of Venting My Gas Tank Sound....help!
Not sure what forum to put this in, but i have seen a bunch of posts on various forums on how to vent a gas tank. I put a Sump on my stock tank and have a completely aftermarket fuel system. I have a bunch of outlets near the upper corners of my tank on both the left and the right corners. I was thinking of using a rubber line as a coupler and using some 1/4" brake line or aluminum and bednign a line to connect from one side to the other (kinda like when people make a line that goes from one float to bowl to the other on Holleys to keep gas from coming out of the vent tubes under braking)
In the middle i would drill a series of holes to vent it, also i was thinking right after it connects to the tank put a series of loops in the line so gas can't come out, kinda like brake lines near your master cylinder, The only think I am thinking is that dirt could get in the small holes after a long time, maybe clog it up? wondering if there is some kind foam i could stick downt the tube?
Any ideas, suggestions? Need to vent this tank, but don't want to use a venting cap, or use some huge charcoal canister.
